The switch one use one port with vlan 1 and there is no other port connect.
I ping from switch to that PC .
I find the ping response time appear steady in a period of time and then suddenly it will jump with bigger delay.
I expect the ping time should be steady all the time as there is no any other traffic from switch to PC .
below is the ping time I observe.You can see usually ping time is within 5 ms but sometime it jump more than 10 ms .
Why and any suggestion ???
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.01.16 09:19:41 =~=~=~=~=~=~=~=~=~=~=~=
64 bytes from 10.1.9.97: icmp_seq=98. time=3. ms
----10.1.9.97 PING Statistics----
99 packets transmitted, 99 packets received, 0% packet loss
round-trip (ms) min/avg/max = 3/12/233
-> ping 10.1.9.97 count 99
PING 10.1.9.97: 56 data bytes
64 bytes from 10.1.9.97: icmp_seq=0. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=1. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=2. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=3. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=4. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=5. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=6. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=7. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=8. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=9. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=10. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=11. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=12. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=13. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=14. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=15. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=16. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=17. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=18. time=33. ms
64 bytes from 10.1.9.97: icmp_seq=19. time=3. ms
64 bytes from 10.1.9.97: icmp_seq=20. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=21. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=22. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=23. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=24. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=25. time=200. ms
64 bytes from 10.1.9.97: icmp_seq=26. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=27. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=28. time=33. ms
64 bytes from 10.1.9.97: icmp_seq=29. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=30. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=31. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=32. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=33. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=34. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=35. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=36. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=37. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=38. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=39. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=40. time=55. ms
64 bytes from 10.1.9.97: icmp_seq=41. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=42. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=43. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=44. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=45. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=46. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=47. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=48. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=49. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=50. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=51. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=52. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=53. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=54. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=55. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=56. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=57. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=58. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=59. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=60. time=4. ms
64 bytes from 10.1.9.97: icmp_seq=61. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=62. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=63. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=64. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=65. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=66. time=6. ms
64 bytes from 10.1.9.97: icmp_seq=67. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=68. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=69. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=70. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=71. time=6. ms
64 bytes from 10.1.9.97: icmp_seq=72. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=73. time=126. ms
64 bytes from 10.1.9.97: icmp_seq=74. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=75. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=76. time=6. ms
64 bytes from 10.1.9.97: icmp_seq=77. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=78. time=7. ms
64 bytes from 10.1.9.97: icmp_seq=79. time=56. ms
64 bytes from 10.1.9.97: icmp_seq=80. time=8. ms
64 bytes from 10.1.9.97: icmp_seq=81. time=13. ms
64 bytes from 10.1.9.97: icmp_seq=82. time=17. ms
64 bytes from 10.1.9.97: icmp_seq=83. time=18. ms
64 bytes from 10.1.9.97: icmp_seq=84. time=21. ms
64 bytes from 10.1.9.97: icmp_seq=85. time=21. ms
64 bytes from 10.1.9.97: icmp_seq=86. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=87. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=88. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=89. time=7. ms
64 bytes from 10.1.9.97: icmp_seq=90. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=91. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=92. time=62. ms
64 bytes from 10.1.9.97: icmp_seq=93. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=94. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=95. time=101. ms
64 bytes from 10.1.9.97: icmp_seq=96. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=97. time=5. ms
64 bytes from 10.1.9.97: icmp_seq=98. time=5. ms
round-trip (ms) min/avg/max = 3/11/200
