hi~
OXE installing on HP DL320 gen8 . but iLO port using with occur below error.
* loadDeviceDriver(SCSI): 0x1
* failed to open /proc/scsi/scsi: No such file or directory
TC1800 checking sata configuration and com1 port setting checked and server status normal.
why oxe install fail from cause ? server problem ? oxe installation file ?
ps : oxe installation again new file in BPWS. but fail.
[Resolution]oxe R10.1.1 29b install on HP DL320 gen8
thkim81
Re: [Resolution]oxe R10.1.1 29b install on HP DL320 gen8
this issue resolved
cause HP server mainboard H/W fault.
HP Engineer enter inside then change mainboard.
clear all!!!!
clear all!!!!
gyiasoumas
Hello thkim81,
I face the same problem as you and I want to send the server back to the supplier. My problem is that we don't have direct HP, but HP reseller in my country so I might have a problem to prove to them that my problem is their hardware's problem.
How did you specify your problem to HP in order for them to analyze the incident and give you a solution?
Thanks in advance
Thanks in advance
unitz
Hi gyiasoumas and thkim81,
We are having the same error. Could you please tell us how it was fixed? TC 1800 and 1897 have not been much of help for this issue.
pci probe found 0 SCSI devices
* in device handler
Thanks so much,
unitz.
* in device handler
Thanks so much,
unitz.
unitz
Hi, The issue has been resolved. There is nothing wrong with the hard drive or sata controller. The virtual serial port has to be set to COM1. All this while we had it set to COM2. Also follow the TC 1897 and 1800. The following knowledge base article is also helpful:
http://alcatel-lucent-enterprise.force. ... l&q=tc1897
Holger
Start ilO Session with command vsp
