Showing Wrong number when do the outside call !!!!
shahin
Post by shahin »
Greetings ,
Anyone can tell me that i cannot able to make outside call from alcatel PBX even the incoming also ,
I check the PRA State using " trkstat 2 6 " it showing IN SERVICE ..
Really i don't know what i can do the next step to find out the PRA line ..
Thank you
Re: Showing Wrong number when do the outside call !!!!
trkstat 2 6 should show you something else like level2 state?
t3 C=2 c=6 is the way to got call trace? plse past the output
past the whole trkstat
shahin
Post by shahin »
Dear Mr. Haroun ,
Thank you for your quick input , please find the below ,
--> Cleaning mtracer...
| 0 | ** | ** | 002 | 06 | * | *** | 165 |
| 1 | ** | ** | 002 | 06 | * | *** | 166 |
| 2 | ** | ** | 002 | 06 | * | *** | 167 |
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
Traces Analyser activated
mtracer started ...
(067678:000001) MTRACER host (1xx.xx..x, governer), version: R10.0-j1.410-40-c-
ae-c82
(067678:000001) MTRACER num: 004, time: 2014/10/29 14:44:51, loss: 0%
| (068931:000002) Concatenated-Physical-Event :
| long: 56 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 1b d4
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 8e -> T2 : B channel 14 preferred
| IE:[6c] CALLING_NUMBER (l=10) -> 21 81 Num : 66438438
| IE:[70] CALLED_NUMBER (l=9) -> c1 Num : 44451565
| IE:[7d] HLC (l=2) 91 81
| (068931:000003) 1206: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 9b d4
| IE:[08] CAUSE (l=3) 81 81 80 -> [81] UNALLOCATED NUMBER
| (069398:000004) Concatenated-Physical-Event :
| long: 52 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 1c aa
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 8f -> T2 : B channel 15 preferred
| IE:[6c] CALLING_NUMBER (l=10) -> 21 81 Num : 44495476
| IE:[70] CALLED_NUMBER (l=9) -> c1 Num : 44451555
| (069398:000005) 1206: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 9c aa
| (072073:000006) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 21 4b
| SENDING COMPLETE
| IE:[04] BEARER_CAPABILITY (l=3) 90 90 a3
| IE:[18] CHANNEL (l=3) a1 83 92 -> T2 : B channel 18 preferred
| IE:[1e] PROGRESS_ID (l=2) 82 83
| IE:[6c] CALLING_NUMBER (l=10) -> 21 83 Num : 44602209
| (072073:000007) 1206: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : a1 4b
| (075016:000008) Concatenated-Physical-Event :
| long: 60 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 26 1e
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 93 -> T2 : B channel 19 preferred
| IE:[1e] PROGRESS_ID (l=2) 82 81
| IE:[6c] CALLING_NUMBER (l=14) -> 11 83 Num : 970595604649
| IE:[70] CALLED_NUMBER (l=9) -> c1 Num : 44451480
| (075016:000009) 1206: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : a6 1e
| (075229:000010) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 26 7f
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 94 -> T2 : B channel 20 preferred
| IE:[6c] CALLING_NUMBER (l=10) -> 21 83 Num : 70077599
| (075229:000011) 1206: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : a6 7f
| (075572:000012) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 27 1b
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 95 -> T2 : B channel 21 preferred
| (075572:000013) 1206: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : a7 1b
| (075633:000014) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 27 32
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 82 -> T2 : B channel 2 preferred
| IE:[6c] CALLING_NUMBER (l=10) -> 21 83 Num : 70701144
| (075633:000015) 1206: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : a7 32
shahin
Post by shahin »
Please find the trkstat ,
| T R U N K S T A T E - PRA T Coupler Crystal_nbr = 2 |
| IN SERVICE Coupler Nbr = 6 |
| Access 0 Type : T2 access : ENABLED level2 : CONNECT2 |
| Trunk Grp 0 0 0 0 0 0 0 0 0 0 0 0 |
| Channel 1 2 3 4 5 6 7 8 9 10 11 12 |
| State F F F F F F F F F F F F |
| Channel 13 14 15 17 18 19 20 21 22 23 24 25 |
| Trunk Grp 0 0 0 0 0 0 |
| Channel 26 27 28 29 30 31 |
| State F F F F F F |
| ALARM COUNTERS |
| NOS | AIS | LOS | FEC/CEC | RAI |
| 14 | 0 | 0 | 0 | 0 |
| NOS : no signal | LOS : loss of synchronization |
| AIS : alarm indication signal | FEC/CEC : Frame/Checksum error counter |
| RAI : remote alarm indication | |
shahin
Post by shahin »
| State F F F F F F |
| ALARM COUNTERS |
1. Your provider fault
2. Your NDP misconfiguration
No other possibility
synchro is good and every thing seems good
the t3 trace is for incoming what 's Num : 44451555 &44451565? extensions or installation number +ddi
are you using public ddi ? if yes is there ddi rules managed according to the npd (as cav said)
another t3 for outgoing to see what's going wrong ?
shahin
Post by shahin »
Hi ,
Anyone can tell me how to check the PRI Line is Working or Not ..?
Thanx
Return to “Media Gateway”
