Hi!
I would like to know what key or combo keys that allows me to hang a remote Ip phone in a telnet session.
When I make a call from a remote Ip phone in a telnet session to a extension I don't know how to hang it and
I have to wait until it finish call by non-response.
Thanks,
Hang a remote IP phone in a telnet session
Re: Hang a remote IP phone in a telnet session
tell us how you make the call... may be we can tell you hiw to hang up the call...
regards...
regards...
It's easy, when you are in a Ip phone with a telnet session make this:
e.g., you want to call to 22345 extension (you can make externals calls, if you want).
NeoPhone>Key 2 -> enter
NeoPhone>Key 3 -> enter
NeoPhone>Key 4 -> enter
NeoPhone>Key 5 -> enter
The call is realised. It's very useful for check remote terminals.
- tot3nkopf
You can use xmon command from CS command prompt also.
(xmon neqtnb 0 0 --> off hook; 2 0 on hook; 3 1 --> dials digit 1; 10 = 0 11 =* 12=#)
never used this both before.
i prefer pilot2a (but therefore csta license is needed). with this you can press any key remotely.
it is well documented in csta v2.7.1 support and maintenance documentation.
regards...
regards...
Telnet to the IP Touch ,
with the command key sim follow by the key number you can simulate key press on the set.
Hang up is key sim 12 whem I remember right. But try it.
