Crystal HW, one sip trunk, intip3 used w/ 3 x Armada (120xDSP).
Call follows like that:
CS wants audio on intip3a, udp port, then, intip3a says with icmp code - this port is closed.
of course - some first call go through, and icmp came from intip3 so - not a firewall, switch, router or sth in the network...
site is K1.520.29e
when i move to intip2a everything works
also:
Found "Dynamic Port Ranges" in xls in system docs, Synthesis of IP flows in OmniPCX Enterprise solution/3BA_29000_2903_XXZZA_14/Jean Philippe MARCHAND/Gilles COURCOUX.
but this file ends on 'GD/GA/GA/INT-IP A/INT-IP B" and only "The range width is constant and contains 256 ports.", for intip3a and 120 channels, i need at least 120x4 ports, so 480.
system docs for R11.0
is it a bug? or anyone have some recend ip flows docs? or have seen this issue around?
