We have in a company, one very old system. From about 2007.
When I login, it is bics_demo_xa.
It is a test system. Is it normal for this test system OPS file and CPU_ID not to be correct. I have a panic flag!
Thanks in Advance!
Demo Bics OPS file problem
- cavagnaro
Re: Demo Bics OPS file problem
As demo it maybe expired and is useless now. You would need to upgrade it and get new demo locks
Thank you a lot!
Please, could you tell me if Alcatel policy is to give demo system like demo system and that is why this license can only work 30 days. After, you need to load license again.
It sounds very logical because my company is using one of the demo systems for company purposes, not demonstration for more then I think 10 years.
This system I have found is Rel:9.1.
Best Regards
Best Regards
- cavagnaro
lol, you are infriging licenses policies...don't have support nor nothing. That is not a demo at all. All licenses that doesn't match a CPU ID on it are expired after 30 days. Last versions of 9.1 onwards doesn't allow that "renewal" type anymore.
Or...somebody sent the original CPU who is licensed and forgot to do the license migration to this new one...try to contact who ever installed that system and dig up on that CPU.
