Hi all
i have problems with the tftp download over a vpn tunnel on customer site. I think its a problem with the tftp blocksize wich is default 1428 so i change it to 512 but tcpdump shows 1428 so i think i have to restart the tftp process.
Any body a idea how i can do this without reboot of the system.
i found something in forum like : service xinetd restart but because i have do this as root im not sure about the impact an maybe missfunction of the system.
may be there are someting like:
dhs3_init -R V24
or
dhs3_init -R SIPMOTOR
i try dhs3_init -R TFTP but nothing i can see
How Restart tftp Service ?
Re: How Restart tftp Service ?
Tftp is only if you have ssh enabled. Do you have it?
About the impact will depend on your applications being used.
Maybe do it out of hours.
Split
Hi cav
Ssh is not enable
You say tftp is only if ssh is enable but gd and ip phones use tftp to download there binary ... my problem is a gd3 here try download but something seems to go wrong so gd3 reset
Ssh is not enable
Only on GD3? I do remember seeing a post about a similar issue days ago. Don't remember the solution...maybe try a quick search
Split
for me only GD3
Seaching found this
viewtopic.php?t=22190
But there no solution, more a workaround.
some logs from GD3:
---------------------- RESET HISTORY ------------------------
Reset -1 reason : hard iplink down restarting at 02:50 23 Jul
Reset -2 reason : hard iplink down restarting at 02:50 22 Jul
Reset -3 reason : startemg failed restarting at 10:43 21 Jul
Reset -4 reason : startemg failed restarting at 10:34 21 Jul
Reset -5 reason : startemg failed restarting at 10:26 21 Jul
on Oxe side:
21/07/14 10:51:27 000001M|004/00/-/---|=2:5864=GD: Configuration file checking alarm (lanpbx) 1
21/07/14 10:51:27 000001M|004/00/-/---|=3:5874=telnet service closed
21/07/14 10:51:27 000001M|004/00/-/---|=2:5865=GD: Delivery file checking failed (binmg) 1
21/07/14 10:51:27 000001M|004/00/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 21
lanpbx i have checked .....
no idea at the moment ....
Seaching found this
some logs from GD3:
on Oxe side:
