TFTP server error
MartinB
TFTP server error
Post by MartinB »
Hi guys
First time ever I am getting this issue
I have an issue with IP phones on rel 9.1 (I1.605.26).
I have loaded the Targets and deliveries. Created empty database and loaded the OPS files. Created the lanpbxbuild file.
It is a standalone cpu. The system comes into service and the phones see the binaries, downloads, flushes, I get 5/5 connecting and then it says on the screen "tftp server error"
under incidents on oxe I see "02/07/14 13:13:56 001001M|---/--/-/---|=2:0746=Configuration error during the download of a TSC/IP set"
In incinfo it tells me I must check the lanpbx.cfg file. which I did and it is correct.
The pabx is not connected to the network now and I have a phone on a power supply connected directly on the pabx. I can ping the phone via the pabx but phone keeps saying tftp server error.
please help?
thank you
Martin
enio.eltz
Re: TFTP server error
Post by enio.eltz »
Show us your lanpbx.cfg file and IP addresses of OXE and IP touch.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
oldboy
Post by oldboy »
Silly question but you have users created?
MartinB
Post by MartinB »
Thank you Oldboy.
That was the issue. I wanted to get phones to download binaries etc. did not think it had to see an extension on the pabx to start up....
What a stupid mistake! haha
thank you for the info! much appreciated.
enio.eltz
Post by enio.eltz »
Wow!!! :o :o
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
MartinB
Post by MartinB »
enio.eltz wrote:Wow!!! :o :o
It doesn't make sense that binary download should have anything to do with an extension on the pabx as one only associates the extension to the mac of the phone once the phone is up. So it was a common mistake. no need to be sarcastic. At least I admitted it was my mistake.
enio.eltz
Post by enio.eltz »
My goal was not being sarcastic, don't get angry with me. I got surprised because the commom step is create an extension before everything. Sorry.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
MartinB
Post by MartinB »
Sorry Enio
I misunderstood you completely.
I apologize.
murraya
Post by murraya »
dont feel bad Martin, I fell into that one.
had a site that needed to expand and went IP phone way. as they had no licenses I set up every thing then once licenses arrived I loaded them. then plugged a phone in and there you go TFTP fault.
spent 1/2 an hour looking at tftp/dhcp before i relised i had not configured a phone.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
MartinB
Post by MartinB »
okay, now I do not feel so bad about it! haha. thank you Murraya
Return to “IP”
