A-party to be displayed when callforwarding on PRA trunk
picki2
Post by picki2 »
Hi all,
I need a guidance how to configure the subject topic, meaning
A------incoming on PRA trunk------>B------outgoing on PRA trunk ------>C,
A,C are external
B is OXE terminal
Need to configure OXE to display A-number as caller on 2nd leg
System: R9.1
Trunk: T2 ISDN all countries
I tried to play with parameters such as:
- Call Diversion in ISDN on "Trunk Groups"
- IE External Forward on "Trunk Group"
- NPD for external forward on "ExternalSignaling Parameters"
but with no positive result.
T3 traces didn't show the A number to be sent at all. Also Cisco router that works as CPE to which OXE is connected didn't show A-number coming on "debug isdn" on proper serial interface. The call is forwarded and B-number is displayed so functionally the scenario is working in all combinations but not as expected.
Do you have any ideas how to configure it properly?
Thanks a lot for your help in advance.
Piotr
tgn
Re: A-party to be displayed when callforwarding on PRA trunk
Post by tgn »
Features must be supported by the external Provider.
Call Diversion needs to be active on Provider end. The Information of an external Forwarding will be transferred in D Channel to the Provider. The Provider will now build up the second Call Leg directly. No B Channel in OXE is needed. No accounting ticket for this Call will be generated in OXE.
NPD for external forwarding. The maneged NPD need to have "authorize for private calling number == True". Also the Provider must not screening the Clip of the Calling Number (Clip no screening). 2 B-Channels are needed for the Call. Accounting ticket in OXE will be generated for this call.
regards....
You are talking about two different features: one is CLI no screening as tgn pointed out; the other one is partial rerouting in ISDN (the features activated by you).
Partial rerouting will only work by my knowledge if incoming and outgoing call is performed through the same trunk. An IE is sent to the public switch and the rerouting is performed there.
picki2
Post by picki2 »
Thanks for your answers.
Processing of Diversion is enabled on SP side. Also screening of Calling is set as tgn said.
On Cisco CPE debug shows some kind of FACILITY came but it's unsupported, maybe there is a problem and not on OXE side.
I'm attaching debug from both Cisco CPE and OXE, and serial int configuration below:
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 1500
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
lbanias
Post by lbanias »
Weird situation ! From the same internal user using forward on no-reply I can see the initial external caller , but with immediate forward I see the installation number! From traces I see that my calling number is not transmitted . IE:[6c] CALLING_NUMBER (l=2) -> 00 81 Num : Why ???
immediate forward
____________________________________________________________________________
| (535972:000002) Concatenated-Physical-Event :
| long: 58 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 24 68
| SENDING COMPLETE
|______________________________________________________________________________
| IE:[18] CHANNEL (l=3) a9 83 8d -> T2 : B channel 13 exclusive
| IE:[6c] CALLING_NUMBER (l=11) -> 21 81 Num : 356400446
| IE:[70] CALLED_NUMBER (l=10) -> a1 Num : 314007861
| IE:[7d] HLC (l=2) 91 81
| (535972:000003) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : a4 68
| (535972:000004) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : PROGRESS (03) Call ref : a4 68
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (535972:000005) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 77 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : FACILITY [62] Call ref : a4 68
| IE:[1c] FACILITY (l=57)
| [91] Discriminator of supplementary service applications
| [a1] INVOKE (l=54):
| Invoke Ident. : 000e (14)
| OP: 000e (14)
| [30] Sequence (l=46)
| [0a] Enumerated (l=1) 01
| [30] Sequence (l=11)
| [80] Context specific (l=9) 33 35 36 34 30 30 34 34 36
| [02] Integer (l=1) 01
| [40] Application (l=9) 04 03 80 90 a3 7d 02 91 81
| [a1] Context specific (l=9)
| [a0] Context specific (l=7)
| [a1] Context specific (l=5)
| [0a] Enumerated (l=1) 02
| [12] Numeric string (l=0)
| [a2] Context specific (l=3)
| (535974:000007) Concatenated-Physical-Event :
| long: 29 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : FACILITY [62] Call ref : 24 68
| IE:[1c] FACILITY (l=9)
| [a3] ERROR (l=6):
| [02] General error (l=1) NotSubscribed (0)
| (535975:000008) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 44 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 04 11
| IE:[70] CALLED_NUMBER (l=11) -> 80 Num : 0356400446
| (535976:000009) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP ACK [0d] Call ref : 84 11
| IE:[18] CHANNEL (l=3) a9 83 8f -> T2 : B channel 15 exclusive
| (535977:000010) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 84 11
| (535986:000011) Concatenated-Physical-Event :
| long: 21 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : 84 11
| IE:[27] NOTIF_INDI (l=1) e0 : call is a waiting call
| (535986:000012) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 18 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : a4 68
| (536036:000013) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : DISCONNECT [45] Call ref : 24 68
| IE:[08] CAUSE (l=2) 85 90 -> [90] NORMAL CALL CLEARING
| (536036:000014) 1421: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 04 11
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (536036:000015) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : RELEASE [4d] Call ref : a4 68
| (536037:000016) Concatenated-Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 24 68
| (536038:000017) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 84 11
| (536038:000018) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 04 11
| (536296:000019) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 24 71
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a9 83 9c -> T2 : B channel 28 exclusive
| IE:[6c] CALLING_NUMBER (l=11) -> 21 81 Num : 770056150
| (536296:000020) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : a4 71
| (536296:000021) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : PROGRESS (03) Call ref : a4 71
| (536296:000022) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : a4 71
| [a1] INVOKE (l=54):
| OP: 000e (14)
| (536298:000024) Concatenated-Physical-Event :
| tei: 0 >>>> message received : FACILITY [62] Call ref : 24 71
| [a3] ERROR (l=6):
| (536298:000025) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : SETUP [05] Call ref : 04 12
| (536299:000026) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP ACK [0d] Call ref : 84 12
| IE:[18] CHANNEL (l=3) a9 83 9d -> T2 : B channel 29 exclusive
| (536300:000027) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 84 12
| (536314:000028) Concatenated-Physical-Event :
| tei: 0 >>>> message received : ALERT (01) Call ref : 84 12
| (536314:000029) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : a4 71
forward no reply
| (538489:000002) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 24 a3
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a9 83 9e -> T2 : B channel 30 exclusive
| (538489:000003) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : a4 a3
| (538489:000004) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : a4 a3
| (538638:000005) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : a4 a3
| [a1] INVOKE (l=54):
| OP: 000e (14)
| [0a] Enumerated (l=1) 03
| (538639:000007) Concatenated-Physical-Event :
| tei: 0 >>>> message received : FACILITY [62] Call ref : 24 a3
| [a3] ERROR (l=6):
| (538640:000008) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 57 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 04 13
| IE:[1e] PROGRESS_ID (l=2) 80 83
| (538641:000010) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP ACK [0d] Call ref : 84 13
| (538642:000011) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 84 13
| (538658:000012) Concatenated-Physical-Event :
| tei: 0 >>>> message received : ALERT (01) Call ref : 84 13
| (538756:000013) Concatenated-Physical-Event :
| long: 26 desti: 0 source: 0 cryst: 2 cpl: 7 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CONNECT (07) Call ref : 84 13
| IE:[29] DATE (l=6) -> date : 26 / 01 / 16 19:15:21
| (538756:000014) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT ACK (0f) Call ref : 04 13
| (538756:000015) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 32 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CONNECT (07) Call ref : a4 a3
| IE:[4c] CONNECTED_NUMBER (l=12) -> 01 81 Num : 0356400446
| (538759:000016) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 24 a3
| (538815:000017) Concatenated-Physical-Event :
| tei: 0 >>>> message received : DISCONNECT [45] Call ref : 84 13
| IE:[1e] PROGRESS_ID (l=2) 82 88
| (538815:000018) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : a4 a3
| (538816:000019) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 24 a3
| (538816:000020) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : a4 a3
| (538816:000021) 1420: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : RELEASE [4d] Call ref : 04 13
| (538817:000022) Concatenated-Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 84 13
NPD for external forward has -1 in calling?
Return to “External Services”
