I have three 6400 switches , I need to make LAG on one switch. And LAG on other two separated switches.
Is that possible ?
LAG on two different boxes
mohdkw
Re: LAG on two different boxes
I am adding a simple diagram to demonstrate the idea.
So guys is that possible?
[attachment=-1]uploadfromtaptalk1399835143460.jpg[/attachment]
devnull
What do you want to achive with that?
A Lag Spanning Multiple Chassis is not supported by 6400.
It works on 6900 (MC-LAG/Virtual Chassis) and 9000 (MC-LAG)
DHL would be an Idea but this only creates a single LAG at the "bottom" switch facing up and a single LAG on each top switch facing down.
mohdkw
To be more clear . we have two MPLS in two different locations connecting to the head office. We want to create active passive link . see attached draw.
So is that doable? Any suggestions ? [attachment=-1]uploadfromtaptalk1399896778260.jpg[/attachment]
