I see that CPC (calling part control) or open loop disconnect is now supported in R10 on eZ32-2 boards http://www.abst.com.tw/abpp/OXE%2010.0/ ... 2010.0.pdf
However I am not finding any documentation on how to configure that. Does anyone know?
Configuring CPC on eZ32-2
tjm0852
Re: Configuring CPC on eZ32-2
I found this:
"To configure the CPC signal on OmniPCX Enterprise, see: module Z32/eZ32 / Configuration procedure / User Declaration."
But navigating the R10.1 documents I see nothing under z32/eZ32 about configuration procedure.
Seems you need to ask ALU about that document. Open an eSR with them to make them know the missing doc.
tjm0852
Thanks, but I do not have access to the BP website to open an eSRcavagnaro wrote:Seems you need to ask ALU about that document. Open an eSR with them to make them know the missing doc.
tjm0852
I found the timer, its a new parameter under user when a user is assigned to a eZ32-2 board.
