How can I get the IP address
Pootie
Post by Pootie »
Please how can i get the ip address of my switch.
I can connect with the console but i want to know the ip address to connect with http
Re: How can I get the IP address
So it is your switch and you don't know IP address? Try default ones
murraya
Post by murraya »
"show configuration snapshot" will output the config and show if IP@ set and web access enabled.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
devnull
Post by devnull »
show ip interface shows all IPs currently configured (and up).
You need to access the switch from a correct vlan though
Pootie
Post by Pootie »
hI,
thanks for yours replies; going to apply yours suggestions and I' ll be back soon
Best Regards
Return to “OmniSwitch 6400”
