What's correct procedure for change de Pass of PC
jonnyals
Post by jonnyals »
I need the all month the change the pass of PC (local Administrator) on OmnPCX Record, what's correct procedure for it ?
thank you!
NY
joao.carlos
Re: What's correct procedure for change de Pass of PC
Post by joao.carlos »
You can create an omnipcxrecord user and put it in Administrators group, and configure the services (OmniRECORD services on services.msc and in IIS) to use this user.
If you need to change it too, so you have to change on the services.msc and the IIS every time you change the password.
Return to “OmniPCX Record”
