the FTP server on the OXE
hi
are there any commands to check the status of the FTP server on the oxe ?
i'm unable to connect with FTP to a particular site and getting 530 and i'm sure it's not credential issue as user and passwd are same true.
i'm sur that's a oxe issue .
Re: the FTP server on the OXE
i've restart the service xinetd but stil get 530 ftp error
ill post wireshark asap
- Tha Tawa'S
You can try :
netstat -l | grep ftp
and if listen on 21port you should get something like this :
But maybe ssh is active on your system ??
tcp 0 0 *:ftp *:* LISTEN
hi tawas and thanks for replay
i got same with nestat -l ftp is listening on port 21 and security is not enabled in my system
this site is causing job failure on the 4760 (synchldap , save and restore). ithink i need more investigation why i m got 530 error .
- Tha Tawa'S
is telnet (and not ssh) connection available with login mtcl and password mtcl's password ??
you can try with dos command :
ftp
open @ip-oxe
mtcl
mtcl's password
And last point, is ftp allowed on your network ???
ftp
open @ip-oxe
mtcl
mtcl's password
- cavagnaro
I do remember having a similar situation some time ago and the issue was that the ftp user db was corrupted. We had to reinstall the OXE software to solve it.
- Tha Tawa'S
what do you mean by "ftp user db" ??
is it for example, matching user and password ?
- cavagnaro
The ftp users list. Even we could read the file somehow the ftp service couldn't. 503 means access error.
- Tha Tawa'S
Ftp users list refers to accounts list ( mtcl, ..) , isn't it ?
Yeah cav your are right i compare different ftp db file of the corrupetd site with others wich works perfectly and i donot seen any diffrence but i think the problme is on the passwd file or some crypted one ( when i edit then with the vi i can't read them ) i think i should reinstall linux .
for the momemnt i done a reverse ftp from the orrupted one to good one , and i use put command instead of get , so i have a copy of mao-dat and ops file
