we have 3 nodes interconnected. Whenever we dial a number inter node which is not created on another node we get a prompt "Network Link is Busy" and "Congestion" messages. But when we call within the node it shows "Wrong Number".
Can anybody provide a suggestion.
Thanks and Regards
Thanzeel
ABC-f: Network Link busy message
Re: ABC-f: Network Link busy message
Users from remote nodes - created like "Network numbers" prefixes or "Routing numbers"? I think with "Network numbers" will be better.
thanzeel
Routing numbers it is created. Network numbers we need to be specific on the numbers right? We are having around 5000 extensions in each of the remote nodes and different numbering plans within intra node due to various locations.
Are your links up? How have you set the inter links up Hybrid? T2?
CHEKC At First the status of links if they are up
if links are are up and every thing is ok youshould got same message if you call a wrong number even you user routing number or network numebr prefix the only diffrence is if the number is not declared onthe destination node you get DIRNUMBER + WRONG NUMBER .
