Digital Diagnostic Monitoring alarm
Yvonne
Post by Yvonne »
I keep getting a DDMRx Optical Power Low Alarm and a DDMTx Output power High warning Alarm on some nodes in the network. What would be the probable cause of these alarms?
KirkwoodCR
Re: Digital Diagnostic Monitoring alarm
Post by KirkwoodCR »
Those alarms are indicating an error on the SFP/XFP
DDMRx Low means the SFP/XFP is receiving a light power lower than the low alarm theshold meaning an issues with the device itself, the fiber run or the SFP/XFP on the other end. Check the DDM stats tab on the node.
DDMTx Output high means the SFP/XFP is transmitting very hot. Could mean a possible SFP/XFP failure at my first guess.
Yvonne
Post by Yvonne »
Thank you very much.
Return to “5620 SAM”
