swlog errors
willmeister
swlog errors
Post by willmeister »
Don't know where to begin so here's the log:
Dec 18 06:26:19 Switch-Core local0.info swlogd: flashManager FlashMgr Main info(5) flashMgrValidateImage_exec: calling system(/bin/validate_image --compareImage1=/flash/certified/Reni.img -- duplicated 2 times!
Dec 18 06:26:52 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) ---- Logging MIP_SET type, command to be sent:
Dec 18 06:26:52 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) MIP_SETF2(23) msg_id(830210125) (APPID_CLI(67/0) -> APPID_CONFIGMANAGER(66)) values:
Dec 18 06:26:52 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Table(67585/0): configManager
Dec 18 06:26:52 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Index: (none, no index)
Dec 18 06:26:52 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Object(43) Name: configWriteMemory
Dec 18 06:26:52 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Object Value(uint32): 1
Dec 18 06:26:52 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) ----------------
Dec 18 06:26:52 Switch-Core local0.info swlogd: vfcm main info(5) [vfccCnfGetFirstQSIEntry:3131] No entries found- duplicated 2 times!
Dec 18 06:26:52 Switch-Core local0.info swlogd: linkAggCmm main info(5) Config saved- duplicated 2 times!
Dec 18 06:26:53 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) ---- Logging MIP_SET type, command to be sent:
Dec 18 06:26:53 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) MIP_SETF2(23) msg_id(832766032) (APPID_CONFIGMANAGER(66/0) -> APPID_SYSTEM_SERVICES(75)) values:
Dec 18 06:26:53 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Table(76814/0): systemServices
Dec 18 06:26:53 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Index: (none, no index)
Dec 18 06:26:53 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Object(3) Name: systemServicesTimezone
Dec 18 11:26:53 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Object Value(hex val): 455354
Dec 18 06:26:53 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) ----------------
Dec 18 06:26:53 Switch-Core local0.emerg swlogd: SES CMD alarm(1) CLI log, user: admin (10.10.80.171), cmd: write memory, result: SUCCESS
Dec 18 06:27:20 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) ---- Logging MIP_SET type, command to be sent:
Dec 18 06:27:20 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) MIP_SETF(14) msg_id(875954253) (APPID_CLI(67/0) -> APPID_CHASSISUPER(64)) values:
Dec 18 06:27:20 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Table(65544/0): chasControlModuleTable
Dec 18 06:27:20 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Index: 65
Dec 18 06:27:20 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Object(2) Name: chasControlVersionMngt
Dec 18 06:27:20 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Object Value(uint32): 2
Dec 18 06:27:20 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) ----------------
Dec 18 06:27:20 Switch-Core local0.info swlogd: flashManager FlashMgr Main info(5) Verifying image directory working on CMM flash- duplicated 1 times!
Dec 18 06:27:20 Switch-Core local0.err swlogd: trapmgr error(2) retrieveChassisTrapsAlert | Failed on read trap information. ERROR: invalid application block- duplicated 4 times!
Dec 18 06:27:57 Switch-Core local0.info swlogd: flashManager FlashMgr Main info(5) flashMgrValidateImage_exec: calling system(/bin/validate_image /flash/working/Ros.img))- duplicated 1 times!
Dec 18 06:27:58 Switch-Core local0.info swlogd: flashManager FlashMgr Main info(5) flashMgrValidateImage_exec: valid- duplicated 5 times!
Dec 18 06:27:58 Switch-Core local0.info swlogd: flashManager FlashMgr Main info(5) flashMgrValidateImage_exec: calling system(/bin/validate_image /flash/working/Reni.img))- duplicated 1 times!
Dec 18 06:28:00 Switch-Core local0.info swlogd: flashManager FlashMgr Main info(5) flashMgrValidateImage_exec: calling system(/bin/validate_image --compareImage1=/flash/working/Ros.img --co- duplicated 1 times!
Dec 18 06:28:00 Switch-Core local0.info swlogd: flashManager FlashMgr Main info(5) flashMgrValidateImage_exec: calling system(/bin/validate_image --compareImage1=/flash/working/Reni.img --c- duplicated 1 times!
Dec 18 06:28:00 Switch-Core local0.info swlogd: ChassisSupervisor bootMgr info(5) Copy running to certified: Synchronizing secondary CMM- duplicated 1 times!
Dec 18 06:28:01 Switch-Core local0.info swlogd: ChassisSupervisor MipMgr info(5) Copy running to certified succeeded; Secondary synchronization succeeded- duplicated 1 times!
Dec 18 06:28:01 Switch-Core local0.emerg swlogd: SES CMD alarm(1) CLI log, user: admin (10.10.80.171), cmd: copy running certified flash-synchro, result: SUCCESS
Dec 18 06:28:02 Switch-Core local0.info swlogd: linkAggCmm main info(5) mip_msg_queuing NO 1 - duplicated 9 times!
Dec 18 06:33:04 Switch-Core local0.info swlogd: linkAggCmm main info(5) mip_msg_queuing NO 1 - duplicated 5 times!
Dec 18 06:36:32 Switch-Core local0.info swlogd: SNMP aluSubagent_main info(5) mipConvertErr_2_SnmpErr | error specified application not loaded- duplicated 3 times!
Dec 18 06:36:42 Switch-Core local0.info swlogd: linkAggCmm main info(5) mip_msg_queuing NO 1 - duplicated 5 times!
Dec 18 06:38:04 Switch-Core local0.info swlogd: linkAggCmm main info(5) mip_msg_queuing NO 1 - duplicated 2 times!
Dec 18 06:42:26 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) ---- Logging MIP_SET type, command to be sent:
Dec 18 06:42:26 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) MIP_SET(4) msg_id(-2133655475) (APPID_CLI(67/0) -> APPID_SYSTEM_SERVICES(75)) values:
Dec 18 06:42:26 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Table(76818/0): systemSwitchLogging
Dec 18 06:42:26 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Index: (none, no index)
Dec 18 06:42:26 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Object(13) Name: systemSwitchLoggingConsoleLevel
Dec 18 06:42:26 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) Object Value(uint32): 2
Dec 18 06:42:26 Switch-Core local0.alert swlogd: MIP_GATEWAY mipgwd alert(3) ----------------
no idea what any of it means. any thoughts?
Re: swlog errors
a lot of questions:
1) new installation? or is your switch running a long time and this messages are new?
2) image version?
3) MCLag or VC or standalone ?
4) are there any errors for the users - or only the log messages? Did all you network work fine?
the mip_gateway message I didn't know. For this you have to open a SR at ALU.
ryukunchang
Re: swlog errors
Post by ryukunchang »
Dear.
Symptoms that I am similar equally happen.
I want to know progress item.
Thx
motog4
Re: swlog errors
Post by motog4 »
Dear.
I have this problem too
who can Help me...
Thx
On_call
Re: swlog errors
Post by On_call »
I have a similar problem, does anyone know why?
SNMP aluSubagent_main ERR: aluSubagent_OID_handler | SET-ACTION - ERROR: 10
swlogd MIP_GATEWAY mipgwd INFO: ---- Logging MIP_SET type, command to be sent:
swlogd MIP_GATEWAY mipgwd INFO: MIP_SET(4) msg_id(1070989377) (APPID_SNMP_AGENT(68/0) -> APPID_VLAN_MGR(8)) values:
swlogd MIP_GATEWAY mipgwd INFO: Table(8200/0): vpaTable
swlogd MIP_GATEWAY mipgwd INFO: Index: 0 1018
swlogd MIP_GATEWAY mipgwd INFO: Object(5) Name: vpaStatus
swlogd MIP_GATEWAY mipgwd INFO: Object Value(int32): 6
swlogd MIP_GATEWAY mipgwd INFO: ----------------
Return to “OmniSwitch 10k”
