How to inserve to FICTIF Coupler 0 on virtual crystal 19
kiirimoses
Post by kiirimoses »
We have setup our callcenter on GCE 1.11 Platform, External calls to GCE service number 8040 is working well as managed through an RSI Configuration in OXE. Weve also managed to configure a local hybrid link to enable us make calls on the local RSI number/service number as shown below.
Hybrid link 2000 (GCE) to node 1 (PERMANENT)
ch_canalb = TRUE deborde_it = TRUE mode_reseau = FALSE
List of accesses
| | Main signalling support | Stby signalling support | Nb |
| Nb | GPA State Position Support | GPA State Support | trk |
| 1 | ON UP (19, 0, 0) B Channel | | 0 |
| 15 | ON UP (19, 0, 1) B Channel | | 0 |
My Problem is that I cant make a call to the local RSI 8040.I get network links out of service. I dont know whether this is attributed to coupler 0 of the virtual crystal 19 which shows REG NOT INIT
| 19 | 0 | FICTIF| | REG NOT INIT | NO PCMS CODE |
| 19 | 1 | INTIP3A| | IN SERVICE | NO PCMS CODE |
| 19 | 2 | INTIP3A| | OUT OF SERV | NO PCMS CODE |
| 19 | 3 | Z_FICTIF| | IN SERVICE | NO PCMS CODE |
Please can anyone advise what could be the problem?
With warm regards
Moses
Re: How to inserve to FICTIF Coupler 0 on virtual crystal 19
Does the RSI has the Local Call Authorization = True?
kiirimoses
Thanks for your quick response,am glad.Responding to what you stated, Local Authorisation is already set to true but the problem of Network links out of service is still there. Below is the RSI Configuration number 8040 pointing to GCE.
| Name : 8040 | Type : Local | Prefix : | Node : 1 |
| Exploitation Category : 0 | Connection Category : 0 |
| External Category : 2 | Taxation Category : Justified |
| Transaction Code Dial. Timer : 150 | Language : 1 |
| Hold On Guide Number : 2 | Wrap up Time : 100 |
| Overflow Time Out : 150 | Overflow Address : |
| Cost Center : 255 | Pause Time : 50 |
| Entity Number : 0 | Digit nb for Transaction Code: 0 |
| Ringing Overflow Address: 8040 | Ringing Overflow Time Out : 150 |
| Enable : STEP2 (1) | Monitor : T |
| Inter Guide : 28 | Local Call Authorization TRUE |
| External Routing Point : FALSE | Public Reroutage [F] |
| Supervised transfer [F] | Application Type : Call Center |
| Business Code : 0 | Wait Before ALERT : TRUE |
| Taxfsda : [T] | Max.Number of Reroute Request : 3 |
| FF0 | |
| CALLER'S LIST |
| Head = -1 | Last = -1 | Nb = 0 | NbMax = 512 |
| NO CALLER |
So I guess that if you do an external call to the RSI it does work, right?
Post your hyblink configuration and the accesses too
What about network licenses in OXE (19 - Corporate network, 80 - ABC VPN)? Not sure - hybrid link will works or not without network licenses.
vad wrote:What about network licenses in OXE (19 - Corporate network, 80 - ABC VPN)? Not sure - hybrid link will works or not without network licenses.
Without. Only paramao option.
Was this configured in Actis (local calls for CCD ticked in Actis) or this was enabled via cfgUpdate? Maybe a memory allocation problem?
Other option is that he has no strategy loaded. Let's see what he answers... if answer
Sent from my XPeria Z
Return to “Shelf”
