GD3 still reboot and didn't complete startup
Sam2009
Post by Sam2009 »
i have GD3 with OXE r9.1, i was need to change IP subnet for this OXE from 192.168.168.0 (CS main: 192.168.168.5 , GD: 192.168.168.8 ) to 192.168.169.0 (main cs: 192.168.169.5 GD: 192.168.169.8 )
but after change IP setting for CS & GD it reboot and didn't startup .
please could any one help me ,my OXE is stopped now.
Dignostic
1 - by checking the booting trace i note that GD face problem with new settings:
kindly find this trace:
Uboot updater is now working ... getting current version information
Check if we need to update with Uboot bootl100/000.012 ...
Current version : bootl100/000.012 / Recorded version : bootl100/000.012
..... Uboot update not needed .....
Net status : yes at 100Mb/s
Call lanpbx_mngt
Authentification lanpbx FAILED --> see /var/log/lanpbx_mngt
LANPBX.CFG contents :
-> TYPE=A4400 VERSION=1 IP_DOWNLOAD=192.168.169.5 IP_CPU1=192.168.169.6 IP_CPU2=192.168.169.4
[Start build_hosts 0]
start of load appli modules phase
Loading modules - please wait ...
[Start RT2LxCMD]
ca_kernel : no vlan set
============ continue_rack_init ==============
DIL SWITCH VALUE = 0x2
1024 Ko - BUFFER ALLOCATED
WARNING : tftp server ad
U-Boot 1.3.0-rc3 (Mar 5 2010 - 11:50:23) 3EH30350AAAM bootl100/000.012
Reset Status:
CPU: e300c4, MPC8377, Rev: 21 at 666.666 MHz, CSB: 333 MHz
I2C: ready
DRAM:
2 - So I reconfig IP of CS to old IP 192.168.168.5
but we can note that GD can't boot from SDRAM , and when it boot from Network , i load files from CS , then ask to formate and rebuild SDRAM . then it reboot again
kindly find this traces:
Booting from SDMMC
Hit any key to stop autoboot: 0
## Booting image at ff8390a8 ...
Image Name: gpioinit.bin
Image Type: PowerPC U-Boot Standalone Program (uncompressed)
Data Size: 2185 Bytes = 2.1 kB
Load Address: 00200000
Entry Point: 00200620
Verifying Checksum ... OK
OK
Watchdog Started
** Unable to read "/boot/u-boot.scr" from mmc 0:1 **
Resetting the board.‎
Reset Status: Software Hard, External/Internal Soft, External/Internal Hard
Booting from NETWORK BOOTP
OK
Watchdog Started
Speed: 100, full duplex
Using TSEC0 device
BOOTP broadcast request 1 in progress ---> 00:80:9f:8d:a8:68
Using TSEC0 device
TFTP from server 192.168.168.5; our IP address is 192.168.1.18
Filename '/DHS3bin/downbin/mg3/standard/binmg3factory'.
Load address: 0x100000
Loading: *#
done
Bytes transferred = 681 (2a9 hex)
## Executing script at 00100000
Using TSEC0 device
Filename '/DHS3bin/downbin/mg3/binmg3linux'.
Load address: 0x4000000
Loading: *#################################################################
done
Bytes transferred = 1851658 (1c410a hex)
Using TSEC0 device
Filename '/DHS3bin/downbin/mg3/binmg3rdimg'.
Load address: 0x6000000
mmcblk0: mmc0:b368 STEC 249856KiB
mmcblk0: p1
IP-Config: Complete:
device=eth0, addr=192.168.1.18, mask=255.255.0.0, gw=192.168.168.1,
host=192.168.1.18, domain=, nis-domain=(none),
bootserver=192.168.168.5, rootserver=192.168.168.5, rootpath=
Freeing unused kernel memory: 148k init
loop: module loaded
PHY: e0024520:01 - Link is Up - 100/Full
Thu Jan 1 00:00:12 UTC 1970
[Script /etc/rc.d/rc.sysinit (PID=903) started by "init"]
[starti802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
ng cron]
crond[All bugs added by David S. Miller <davem@redhat.com>
1330]: crond 1.7.2 started, log level 8
[SetEthernet Channel Bonding Driver: v3.1.3 (June 13, 2007)
ting kernel/netwbonding: MII link monitoring set to 200 ms
ork/platform options]
[inserting kernel modulesbonding: bond0: making interface eth0 the new active one.
inserting 802bonding: bond0: first active interface up!
1q ()
insertingbonding: bond0: enslaving eth0 as an active interface with an up link.
bonding (mode=1bonding: bond0: Warning: failed to get speed and duplex from eth1, assumed to be 100Mb/sec and Full.
[Lock reset management to kernel module]
[start loopback device]
[starting network]
[Check Storage device]
[Check SDcard partition]
[Try to mount SDkjournald starting. Commit interval 5 seconds
card partition]
EXT3 FS on mmcblk0p1,
internal journal
EXT3-fs: mounted filesystem with ordered data mode.
[SDcard partition OK]
[BOOT directory to be updated]
End of platform init
[Wait for 5m before rotating log to keep header]
Wed Oct 9 13:31:20 UTC 2013
[Script /etc/rc.d/rc (PID=1484) started by "init"]
=== BIENVENUE TO Media Gateway 3 Software v. 03.33.1 in MGD / GD role ===
=== Kernel version : 2.6.23.17-020.001 ===
[Warning : Boot from network]
=== ByPass SDcard formatting ? (type "y" before 20s, default is format) :
PHY: e0024520:01 - Link is Down
bonding: bond0: link status definitely down for interface eth0, disabling it
bonding: bond0: now running without any active interface !
[Warning : Please wait, SDcard will be now formatted and checked with mg3 as owner]
[Try to mount SDcard pirtition]
[Need to rebuild SDcard storage].....
mmcblk0: t1
mmcblk0: p1
bonding: bond0: link status definitely up for interface eth0.
EXT3 FS on mmcblk0p1, internal journal
[SDcard partition rebuilded]
گ!!!!!!!00/000.012
Reset Staôus:
I2C: ready
DRAM:
DDR DIMM: data bus width is 64 bit without ECC
////// when i don't select to formate:
Wed Oct 9 13:30:27 UTC 2013
[Script /etc/rc.d/rc (PID=1523) started by "init"]
y
=== NO SDcard formatting ===
!!!! FACTORY MODE ENABLED !!!!
Reset Status:
Sam2009
Re: GD3 still reboot and didn't complete startup
Post by Sam2009 »
If I need to reload the flash memory.
where i can get new binary file and how ac i know the version
Return to “Media Gateway”
