ALCATEL OXE question
MOHAMED pc world
i have alcatel oxe for 1000 user (500 ip/500 analog) connect throw fiber network
my question is what i need to connect this system ?
note : i have ONT contain fxs port
thank you
thank you
- tot3nkopf
Re: ALCATEL OXE question
I do not understand your question. Can you reformulate?
MOHAMED pc world
i have hotel with 1000user (500 ip / 500 analog) i establish optic fiber network in this hotel
i want to establish ip phone throw this net work
i will use alcatel omnipcx oxe as pbx on other side i use vgr21412 as ont (optical network terminal) which including fxs port and support voip
my question is what i need for analog phone in this network ??
did i need analog board for analog phones or with this ont the analog phone will turn to ip phone
thank you
thank you
MOHAMED pc world
i want to connect analog phone with alcatel ip pbx throw optical fiber network using ont (optical fiber terminal) vgr 21412 [is support voip and contain fxs port]
http://www.ctsystem.com/product/Product ... x?pdno=311
what i need to do that ??
- tot3nkopf
You either need SIP extensions on OXE side and you should check/test MWI compatibilities for hotel mode for your software release, or use FXO to SIP gateway on OXE side (connect analog users to FXO gw on OXE side) and link it to terminated FXS ports.
Something like this:
1. OXE SIP -->ONT netw (SIp transport) -->SIP to FXS GW (VRGIII-31412-N)--> phone
2. OXE analog pots --> FXO to SIP gw (whatever vendor) --> ONT netw --> SIP to FXS GW (VRGIII-31412-N) --> phone
For first scenario you must have OXE software license over R9 and SIP user licenses.
Look also here:
viewtopic.php?f=230&t=4493&hilit=hotel+sip
Look also here:
MOHAMED pc world
thank you tot3nkopf
my case is first scenario
this what i need i post another topic about this subject
viewtopic.php?f=327&t=22419
RANJIT KAUR
which command is used to display running configurations in alcatel devices??????
Devices? PABX (OXO, OXE), switches...?
