about aclman
chuikingman
about aclman
Post by chuikingman »
From my understand , aclman can allow you to input cisco command to configure the switch.So, even user do not ALU command , they can use CISCO command to configure ???
I want to know whether it is possible or not ???
For exaample , how can I use aclman to configure below
1)assign port to one vlan addr
2)create vlan addr
3)create ip interface and link to specific vlan addr ...
4)add ip static route..
Please advice .
Thank
devnull
Re: about aclman
Post by devnull »
You are wrong.
ACLMAN ist the ACL Manager, means you can use Cisco-Style ACLs. (read the manual?)
You need to configure interfaces, vlans aso in Alcatel Style on Alcatel CLI.
Furtheron: ACLMAN implemented ACLS are AFAIK not visible in the config, so you may (in a year or so) have forgotten that there are ACLs limiting your traffic, when you are debugging errors- which is really a pain in the a**.
I would not use ACLMAN if possible (while i must admit, that i like Cisco ACLs much more that Alvcatel QoS- Policys)
Return to “OmniSwitch 6400”
