EMP interface and routing
larsen
Post by larsen »
Hi I have a SO6900 where I would like to manage the switch over the EMP interface instead of a normal port, for out of band management purposes.
I seem to fail in terms of getting a connection from something outside the the local subnet of the EMP interface.
So my question is can you use the EMP port for out of band managment ? You should be able to do that imho since there is a command to see what emp-routes you have in the machine.
However there is no way to configure emp-routes as I see it.
I'm a bit of a alcatel lucent noob so please bare with me =)
Below is my current config.
mac-retention admin-state enable
mac-retention dup-mac-trap admin-state enable
mac-retention timer 30
! Configuration:
! Capability Manager:
! Multi-Chassis:
! Virtual Chassis Manager:
! Virtual Flow Control:
! Interface:
! Link Aggregate:
! VLAN:
vlan 1 admin-state enable
! Spanning Tree:
spantree vlan 1 admin-state enable
! Bridging:
! Port Mirroring:
! Port Mapping:
! IP:
ip service port 21 admin-state enable
ip service port 22 admin-state enable
ip service port 23 admin-state enable
ip service port 80 admin-state enable
ip service port 123 admin-state disable
ip service port 443 admin-state enable
ip interface emp address X.X.X.X mask 255.255.255.0
! IPv6:
! IPSec:
! IPMS:
! AAA:
aaa authentication telnet "local"
! NTP:
! QOS:
! Policy Manager:
! VLAN Stacking:
! ERP:
! MVRP:
! LLDP:
! UDLD:
! Server Load Balance:
! High Availability Vlan:
! Session Manager:
! Web:
! Trap Manager:
! Health Monitor:
! System Service:
! SNMP:
! BFD:
! IP Route Manager:
ip static-route 10.10.48.0/22 gateway X.X.X.X metric 1
ip static-route 172.0.0.0/12 gateway X.X.X.X metric 1
! VRRP:
! UDP Relay:
! RIP:
! OSPF:
! ISIS:
! IP Multicast:
! DVMRP:
! IPMR:
! RIPng:
! OSPF3:
! BGP:
! Netsec:
! Module:
! RDP:
! DA-UNP:
! DHL:
! Ethernet-OAM:
! SAA:
! SPB-ISIS:
! SVCMGR:
! LDP:
benny
Re: EMP interface and routing
Post by benny »
You can use the static-route command, but you can't specify a default route that goes through EMP.
B
larsen
Post by larsen »
That is what I have tried but nothing get's routed out from the interface since the routing table is empty.
show ip routes
+ = Equal cost multipath routes
Total 1 routes
Dest Address Gateway Addr Age Protocol
127.0.0.1/32 127.0.0.1 2d21h LOCAL
show ip emp-routes
Total 3 routes
Dest Address Subnet Mask Gateway Addr Age Protocol
10.10.48.0 255.255.252.0 172.18.237.1 2d21h STATIC
172.0.0.0 255.240.0.0 172.18.237.1 2d21h STATIC
172.18.237.0 255.255.255.0 172.18.237.30 2d21h LOCAL
But I can't ping anything on the 10.10.48 network or the 172.0.0.0/12 network. The packet doesn't go thru.
// Andreas
benny
Post by benny »
Does your gateway receive the request?
B
larsen
Post by larsen »
I can telnet from the gateway ( another router ) to the EMP interface. I haven't on the router itself yet. But I plan on doing that if I can't get this to work soon.
// Andreas
benny
Post by benny »
Andreas,
For me your issue sounds like a routing issue. Please verify if the request to reach the client in 10.x segment gets received by that client and what happens to the response. If your client doesn't receive the request, there will obviously be no response.
You can use "debug ip packet start timeout 30" and then issue the ping attempt from your OS6900 to do initial troubleshooting. (The output on your console will automatically end after 30 seconds)
B
Return to “OmniSwitch 6900”
