I upload the voice guide in to the Media Gateway
My Prefix Plan use 4 and 5 in the first
I want change it t0 * and # and i want assign voice guide to this
means instead of say press 41 to cancel forward , say press *1 to cancel forward
thank you
Majid Dejimand
Change Prefix Standard
- tot3nkopf
Re: Change Prefix Standard
You are using generic (predefined) voice guides. Easiest way is to change the prefix plan not the voice guide. Add 41 as cancel forwarding.
majid2236
yes its correct but i want to change voice speaking
for example instead of say 41 the voice guide say *1
If you have ALL prefix in default plan 44/74/*4 - you can manage VG (check Technical communication folder on VG disk - if you have this CD).
If you have prefixes in random way - some with *, another with # and different from default - you need to create VG project (write wav files with VG what you want, create project with Alcatel Audio Station SW).
