Outgoing calls Elastix => OXO Bad Gateway
Re: Outgoing calls Elastix => OXO Bad Gateway
It is not only about joining.
You need to assign the SIP trunk group the same rights as you have assigned a normal user ion order to dial a certain number.
luis.molinas
Post by luis.molinas »
Yes, i have configured the same rights in the sip trunk group.
I think that the OXO when receives an external number from Remote GW, didn't forward to public network, and it respond with "404 Not Found".
or l some prefix is on worng translation or missing (i'm thinking for oxe)
besacier
Post by besacier »
I have exactly the same problem can someone share a working config on the oxo side
hcoello
Post by hcoello »
Did you make it work?
if yes how you resolve?
Return to “Asterisk”
