8082 video in OXO
jancek
8082 video in OXO
Post by jancek »
Did anyone try to use video call between 8082 and some other video SIP phone in OXO? For example between some doorcam and 8082? I tried to use doorcam 2N Helios IP Vario, but if I call 8082 there is no video. Everywhere in the Technical documentation there is explanation about video only between 8082 phones. Thanks,
Jancek
enio.eltz
Re: 8082 video in OXO
Post by enio.eltz »
OXO version??
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
jancek
Post by jancek »
It is: R900_048_001.
Jancek
enio.eltz
Post by enio.eltz »
Is 8082 release 260?
Is 8082 generation 2?
Video is only supported on these ones. And there is a black list regarding the video doorphone.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
jancek
Post by jancek »
Hi, thanks for help. Offcourse, I have V2 8082 and FW 260. But why doesn't it work with other SIP phones? Why only with 8082 phones?
abdulraouf
Post by abdulraouf »
what about oxe r10.1.1 and integration with linkcom or Algo 8036 door unit.
did anyone tried video call from the door-phone to 8082?
robertvg
Post by robertvg »
I'm also looking for the feature of a video connection with a doorphone.
If a standard video connection to the SIP phone is not possible, is it then possible to connect directly to the H264 videostream of the doorphone ?
Using a webapp or so ?
jawad555
Post by jawad555 »
Nice comments About 8082 video in OXO. Thanks for information.
jawad555
Post by jawad555 »
8082 video in OXO, I suggest you please google search for solving problem.
Eagle1
Post by Eagle1 »
the 8082 supports video in R910 and R920 with the Linkcom doorphones (amongst a couple of others)
It also works with the Bria Softphone with video (purchased version)
ALU has an IWR on the Linkcom with the OXO on their web site.
Cheers,
Eagle1
Return to “My IC Phone”
