U-Boot 1.3.0-rc3 (Mar 5 2010 - 11:50:23) 3EH30350AAAM bootl100/000.012
Reset Status: Software Hard, External/Internal Soft, External/Internal Hard
CPU: e300c4, MPC8377, Rev: 21 at 666.666 MHz, CSB: 333 MHz
I2C: ready
DRAM:
DDR DIMM: data bus width is 64 bit without ECC
DDRC ECC mode: OFF
DDR RAM: 256 MB
FPGA: /soc@e0000000/gpio@c00/fpga@01f00000: FPGA4C1NV reloading... done
FLASH: 2 MB
PCI: Bus Dev VenId DevId Class Int
00 17 1064 2102 0000 00
00 18 1064 2102 0000 00
00 1d 10ee 0300 0b40 ff
In: serial
Out: serial
Err: serial
Net: TSEC0, TSEC1
eSDHC: 4bit-buswidth mode
SATA: SATA0 [Link: no RDY]
SATA1 [Link: no RDY]
## Booting image at ff836de0 ...
Image Name: aleboot.bin
Image Type: PowerPC U-Boot Standalone Program (uncompressed)
Data Size: 8840 Bytes = 8.6 kB
Load Address: 00200000
Entry Point: 00201954
Verifying Checksum ... OK
OK
m41t11 Chip
No Prompt
Press ^B^I to enter into the Bios menu 0 Booting from SDMMC
Hit any key to stop autoboot: 0
## Booting image at ff8390a8 ...
Image Name: gpioinit.bin
Data Size: 2185 Bytes = 2.1 kB
Entry Point: 00200620
OK
Watchdog Started
898 bytes read
## Executing script at 00100000
1851658 bytes read
10177018 bytes read
## Booting image at 04000000 ...
Image Name: Linux-2.6.23.17-020.001
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 1851594 Bytes = 1.8 MB
Load Address: 00000000
Entry Point: 00000000
Uncompressing Kernel Image ... OK
## Loading RAMDisk Image at 06000000 ...
Image Name: OXE_NGP_2.0_int
Image Type: PowerPC Linux RAMDisk Image (gzip compressed)
Data Size: 10176954 Bytes = 9.7 MB
Requesting system reboot
Restarting system.
ÿ
I2C: ready
DRAM:
DDRC ECC mode: OFF
DDR RAM: 256 MB
FLASH: 2 MB
In: serial
Out: serial
Err: serial
Net: TSEC0, TSEC1
OK
m41t11 Chip
No Prompt
OK
Watchdog Started
898 bytes read
1851658 bytes read
10177018 bytes read
Booting using the fdt at 0x5800000
Loading Ramdisk to 0f5ea000, end 0ff9e9ba ... OK
Loading Device Tree to 007fd000, end 007fefff ... OK
setup_arch: bootmem
ale8377_intip3_setup_arch()
arch: exit
Using Alcatel-Lucent 8377 INTIP3 machine description
Linux version 2.6.23.17-020.001 (dri@frillux) (gcc version 4.1.2) #1 PREEMPT Thu Jul 16 11:07:18 CEST 2009
Found initrd at 0xcf5ea000:0xcff9e9ba
[MTD] Found 5 partitions in device-tree
Found MPC83xx PCI host bridge at 0x00000000e0008500. Firmware bus number: 0->0
Zone PFN ranges:
DMA 0 -> 65536
Normal 65536 -> 65536
HighMem 65536 -> 65536
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0 -> 65536
Built 1 zonelists in Zone order. Total pages: 65024
Kernel command line: root=/dev/ram console=ttyS0,9600 powersave=off boot_from=flash console_baudrate=9600 factory_mode=no
IPIC (128 IRQ sources) at fcff9700
PID hash table entries: 1024 (order: 10, 4096 bytes)
I-pipe 2.0-09: pipeline enabled.
console [kgdb0] enabled
Console: colour dummy device 80x25
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 245180k/262144k available (3684k kernel code, 16636k reserved, 156k data, 525k bss, 148k init)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
Found MPC8377 (hardware revision 2.1)
Read ALE devices configuration from DeviceTree
NULL bootp pointer
PCI: Probing PCI hardware
Generic PHY: Registered new driver
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
checking if image is initramfs... it is
Freeing initrd memory: 9938k freed
prom_parse: Bad cell count for /soc@e0000000/mdio@24520/ethernet-phy@1
prom_parse: Bad cell count for /soc@e0000000/mdio@24520/ethernet-phy@2
Xenomai: system heap size: 16384 kB
I-pipe: Domain Xenomai registered.
Xenomai: hal/powerpc started.
Xenomai: init success
I-pipe: Domain IShield registered.
Xenomai: real-time nucleus v2.4.5 (Overdriver) loaded.
Xenomai: starting native API services.
Xenomai: starting POSIX services.
Xenomai: starting RTDM services.
Xenomai: starting RTAI emulator.
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0xe0004500 mem 0xd1002500 (irq = 20) is a 16550A
console [ttyS0] enabled
serial8250.0: ttyS1 at MMIO 0xe0004600 mem 0xd1004600 (irq = 21) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
Gianfar MII Bus: probed
eth0: Gianfar Ethernet Controller Version 1.3-skbr, 00:80:9f:8d:47:4e
GFAR: SKB Handler initialized at CPU#0(max=32)
eth0: MTU = 1500 (frame size=1526, truesize=1808)
eth0: Running with NAPI disabled
eth0: 1024/256 RX/TX BD ring size
eth1: Gianfar Ethernet Controller Version 1.3-skbr, 00:80:9f:8d:47:4f
eth1: MTU = 1500 (frame size=1526, truesize=1808)
eth1: Running with NAPI disabled
eth1: 1024/256 RX/TX BD ring size
kgdboe: couldn't parse config at not_configured!
kgdboe: configuration incorrect - kgdboe not loaded.
Usage: kgdboe=[src-port]@[src-ip]/[dev],[tgt-port]@<tgt-ip>/<tgt-macaddr>
physmap platform flash device: 00200000 at ff800000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.0: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using physmap partition information
Creating 4 MTD partitions on "physmap-flash.0":
0x00000000-0x000e0000 : "firmware"
0x000e0000-0x00100000 : "hardware"
0x00110000-0x001f0000 : "fs"
0x001f0000-0x00200000 : "factory"
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 38, io base 0xe0023000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
esdhc: Freescale Enhanced Secure Digital Host Controller driver
esdhc:slot0: SDCard is Full-Speed Capable (25 MHz)
esdhc:slot0: Invalid maximum block size, assuming 512
mmc0: ESDHC at 0xe002e000 irq 42 DMA
TCP cubic registered
NET: Registered protocol family 17
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Freeing unused kernel memory: 148k init
esdhc:slot0: SDCard clock is now running at 372023 Hz
esdhc:slot0: SDCard clock is now running at 23809523 Hz
mmc0: new SD card at address b368
mmcblk0: mmc0:b368 STEC 249856KiB
mmcblk0: p1
loop: module loaded
Thu Jan 1 00:00:10 UTC 1970
[Script /etc/rc.d/rc.sysinit (PID=901) started by "init"]
[starti802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
ng cron]
crond[All bugs added by David S. Miller <davem@redhat.com>
1338]: crond 1.7.2 started, log level 8
[SetEthernet Channel Bonding Driver: v3.1.3 (June 13, 2007)
ting kernel/netwbonding: MII link monitoring set to 200 ms
ork/platform options]
[insertinbonding: bond0: Warning: failed to get speed and duplex from eth0, assumed to be 100Mb/sec and Full.
g kernel modulesbonding: bond0: making interface eth0 the new active one.
inserting 802bonding: bond0: first active interface up!
1q ()
insertingbonding: bond0: enslaving eth0 as an active interface with an up link.
bonding (mode=1bonding: bond0: Warning: failed to get speed and duplex from eth1, assumed to be 100Mb/sec and Full.
bonding: bond0: enslaving eth1 as a backup interface with an up link.
inserting x_tables ()
inserting ipt_ttl ()
inserting ipt_TTL ()
inserting ip_tables ()
ip_tables: (C) 2000-2006 Netfilter Core Team
inserting xt_NFLOG ()
inserting xt_NFQUEUE ()
Netfilter messages via NETLINK v0.30.
inserting nfnetlink_queue ()
inserting nfnetlink_log ()
inserting iptable_filter ()
inserting iptable_mangle ()
inserting iptable_raw ()
inserting xt_tcpudp ()
insertintun: Universal TUN/TAP device driver, 1.6
g xt_mark ()
intun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
serting xt_MARK bonding: bond0: link status definitely down for interface eth0, disabling it
bonding: bond0: making interface eth1 the new active one.
inserting tun ()
inserting alz-driver ()
Register platform Alcatel-Lucent 8377 INTIP3 specific functions
Invalid magic in bootp request
[wdt] Driver Initialization
cCPU Watchdog Timer not enabled (60 seconds, nowayout=0) tdelay=1000
bonding: bond0: link status definitely down for interface eth1, disabling it
bonding: bond0: now running without any active interface !
rtc model m41t11
m41t11 0-0068: rtc core: registered m41t11 as rtc0
[alz] Register alz_gpio...
[alz] Register Armada EEPROM drivers
Registered led device: CPUgreen
Registered led device: CPUred
Registered led device: CPUyellow
Registered led device: BSYyellow
[Restore system m41t11 0-0068: read: 49 24 d0 06 01 03 13
m41t11 0-0068: read secs=49, mins=24, hours=10, mday=1, mon=2, year=113, wday=5
Fri Mar 1 10:24:49 UTC 2013
[starting background processes]
[starting syslogd]
[Lock reset management to kernel module]
[start loopback device]
[starting network]
[Check Storage device]
[Check SDcard partition]
[Try to mount SDkjournald starting. Commit interval 5 seconds
EXT3 FS on mmcblk0p1,
internal journal
EXT3-fs: mounted filesystem with ordered data mode.
[SDcard partition OK]
[BOOT directory to be updated]
End of platform init
[Wait for 5m before rotating log to keep header]
Fri Mar 1 10:24:50 UTC 2013
[Script /etc/rc.d/rc (PID=1505) started by "init"]
=== BIENVENUE TO INTIP 3 Software v. 04.03 in INTIP3 board / intip3 mode / INTIPB role ===
=== Kernel version : 2.6.23.17-020.001 ===
***** SDcard owner = intip3 ***** Board = intip3 *****
[Retrieve IPMG configuration]
/mnt/flash/local/ipmg.cfg: OK
Find ipmg.cfg configuration file in /mnt/flash/local
/mnt/flash/local/startup.cfg: OK
Find startup.cfg configuration file in /mnt/flash/local
/mnt/flash/local/pcs.cfg: OK
Find pcs.cfg configuration file in /mnt/flash/local
Reading of configuration in flash finished
No password file found - using default password list
PHY: e0024520:01 - Link is Up - 1000/Full
bonding: bond0: link status definitely up for interface eth0.
Duplex mode set to 1 BUT forced to auto-negociation mode
Starting /etc/rc.d/rcS/01pipe
Starting /etc/rc.d/rcS/10network
Setting hostname....
[Start mod_incid
INCIDENT_DEVICE :: INCIDENT driver registered to Linux
.ko]
[Start net_restart]
bonding: bond0: Warning: the permanent HWaddr of eth0 - 00:80:9F:8D:47:4E - is still in use by bond0. Set the HWaddr of eth0 to a different address to avoid conflicts.
bonding: bond0: releasing active interface eth0
bonding: bond0: releasing backup interface eth1
bonding: bond0: enslaving eth1 as a backup interface with a down link.
Bringing up interface bond0 ....
Detected current net interface : eth0
[Checking duplicated IP addr 10.10.160.12 through bond0]
[ IP addr checked and DOES NOT appear duplicated ]
IPv4 packet forwarding is enabled....
IPv4 automatic defragmentation is disabled....
IPv4 TCP timestamps is disabled....
Starting /etc/rc.d/rcS/90init
Uboot updater is now working ... getting current version information
Check if we need to update with Uboot bootl100/000.012 ...
Current version : bootl100/000.012 / Recorded version : bootl100/000.012
..... Uboot update not needed .....
[Warning] Net status : yes at 1000Mb/s
[Warning] Call lanpbx_mngt
Authentification lanpbx FAILED --> see /var/log/lanpbx_mngt
LANPBX.CFG contents :
-> TYPE=A4400 VERSION=1 IP_DOWNLOAD=10.10.160.3 IP_CPU1=10.10.160.2 IP_CPU2=10.10.160.1
[Start build_hosts 0]
start of load appli modules phase
Loading modules - please wait ...
[Start RT2LxCMD]
[Start xeno_bkRegistering Adeos/Xenomai Backtrace
t.ko]
[xeno_bkt]: Albator pid is 1470
[Start xeno_ipmgxeno_ipmg_drv: module license 'Alcatel-Lucent' taints kernel.
_drv.ko]
ipmg_drv module loaded
/proc/IPMG proc entry created
[Start inox_hpi.ko & inox_pci.ko common interfacInox_pci found 0 Dsps
e]
Inox_pci found 2 Dsps
[Start dbg_mngr.ko and fw_mngr.ko telecom DSPs lModule rt_printf loaded
ow level managemStarting monitor using pipe 1
ent]
[Start xenUUo_printf.ko]
[Start xeno_monitor.ko]
binamcvb642x AUTHENTICATION OK
[Start amcvd.ko common interface]
nbInox:2 dspInfos.InoxId:1 dspInfos.Pos:0 inoxTelId:0 => dspId:0
nbInox:2 dspInfos.InoxId:1 dspInfos.Pos:1 inoxTelId:0 => dspId:1
DSPWare Version : AMCVB / 2.20 / Checksum 04ef7d03
[Start adiat_driCreate /proc/adiat
ver.ko common inAdiat driver module loaded
terface]
[Start xeno_mem_/proc/IPMG/DMAMemoryManager proc entry created
mgr.ko]
rt_mem_mgr : General Heap for Real Time : 16777216 bytes
DMA memory allcator initialized : 20 chunks of 131072 bytes
Real-Time Linux Dynamic Memory Manager
[Start xeno_syscxeno_syscall : module loaded.
all.ko]
[Start xeno_syscall_agent]
[Start xeno_ca_kernel.ko]
Application specification : intip3
Alcatel-Lucent kernel module loading...
---------------- Rings Init : Begin ---------------
ca_kernel : Creating Heap Tx [ OK ]
ca_kernel : Allocating Heap Tx [512] [ OK ]
ca_kernel : Creating Heap Rx [ OK ]
ca_kernel : Allocating Heap Rx [512] [ OK ]
---------------- Rings Init : End -----------------
fastsk : Shared heap allocated
Module Kernel Loaded
[Start Socket Agent]
[Start c1nv_mngt.ko]
[Use of /mnt/flash/local/tonesnv]
pci_get_device cffe9000
pci_enable_device 0
pci_request_region 2 0
ioremap 2 d3a00000
pci_request_region 1 0
ioremap 1 d3a80000
pci_request_region 0 0
ioremap 0 fcffe400
[PowerOff] (IRQ #0 (0) received).
irq = 18
request_firmware BNVINTIP 0 d22f2fd8
request_firmware TONES 0 d22f3128
[Start intip_mngt.ko]
SoftMSM_Sig = 0
Fri Mar 1 10:25:26 UTC 2013
[Script /etc/rc.shutdown (PID=1861) started by "init"]
Script Log disabled
[Notify RT application to engage shutdown]
ca_kernel : Fast Socket Initialization.
ca_kernel : no param_8021q=-1 is used
ca_kernel : no vlan set
Module INTIP Loaded
[Start c1nv_procDirectory /mnt/flash/info/c1nv OK
.ko]
/mnt/flash/info/c1nv/c1nvnorst doesn't exist -1
Next idx_hist: 2
[Start srtp_module.ko]
SRTP Module is loaded but security is not implemented in this release
[Start ca_media_server.ko]
[Notify RT application to halt now]
[Backup system tm41t11 0-0068: write secs=29, mins=25, hours=10, mday=1, mon=2, year=113, wday=5
ime to RTC]
m41t11 0-0068: write 29 25 d0 06 01 03 13
Fri Mar 1 10:25:30 UTC 2013
[Script /etc/rc.d/init.d/save_info (PID=1883) started by "/etc/rc.shutdown"]
[No backtrace]
[No new core dump]
[Saving logs]
[Stopping swap]
[Lazy Unmounting everything]
media Module is loading (setcomphs=0)...
media Module version Feb 8 2012-15:45:53
media Module Author Written by ALE ...
Starting Load of media server module
End of update_obj_tb phase
End of determine_offset phase : 9 objects passed
Start of allocators construction phase (static)
init module media_server : after allocation of VoIP context objects pools
[Stopping network]
[End of rc.shutdown]
The system is going down End of loop on channels from 0 to 128
NOW!
Sending SBefore special objects treatment : RTCP RR and fastsk for RTCP and T38 objects
IGTERM to all prEnd of link on fastsk objects for RTCP_RR : inst numbers from 128 to 255
ocesses
SyscallEnd of link on fastsk objects for RTCP_SR : inst numbers from 256 to 383
Agent[1827]: SigEnd of link on fastsk objects for udptl : inst numbers from 384 to 511
nal 15 catched -fastsk objects srtp for Thales box : inst number 512
-> shutdown!!!
fastsk objects fax for Thales box : inst number 513
SyscallAgent[Module media_server loaded
1827]: rt_syscalmedia server module is loaded
l0 closed
xeno_syscall_agent[1827]: End
Sending SIGKILL to all processes
