How to reset AP85- TX ( help please)
Also known as OmniAccess Instant AP
laithlaithlaith
Post by laithlaithlaith »
Hello Guys ,
hope you well
> I have Antenna ma58 1x mnt (MA-WA58-1X) device with AP85-tx access point, and I have problem I cann't access the
Please , Can you help me , how to make reset the AP85-tx because someone change Ip address and put it password ,
> Thanks in advance
Re: How to reset AP85- TX ( help please)
you can reset the AP85 like the other AP via console. You can use same SOE-Adapter like for AP60/61/65/70. Or you make your own adapter (see instruction guide).
You have to interupt the boot and with purgeenv and saveenv you can reset the AP to factory.
laithlaithlaith
Please can you teach me by instruction .. or by image please :(((
here the instruction guide with SoE-port.
Return to “OmniAccess Wireless Access Points”
