I have an OXO in the main site and other OXO in a remote site, these PBX are routed by ARS Table through Voip trunk. I need to Transfer an incoming call from the main site to the remote site through the ip trunk. How can I do that?
Please... I tried the divertions from one place to another and it works, but the transfer not.
Anybody can Help me?
TRANSFER TO THE MAIN SITE TO REMOTE SIDE BY TRUNKING IP
- giovanni.attolini
Re: TRANSFER TO THE MAIN SITE TO REMOTE SIDE BY TRUNKING IP
Transfer by an internal user: you need to use the normal proccess of call transfer but using the extension number of other site previously maped in the "internal numbering plan".
Transfer by system (incoming call routed to an extension of the other site): you need create the DID entry in "public numbering plan" routed to ARS, in the ARS you need to treat this DID to send it to the other site, on the other site you need to create the entry in "private numbering plan" routed to the right user. Take care with TG category and trunk category and remember that the trunk of incoming call needs permission to take the TG to go to the other site.
Giovanni A. Attolini
icolmenter
Thanks so much, i will try with this configuration and let you know the result.
- giovanni.attolini
Take care to external transfer too, the user that is doing the transfer needs permission (user feature - external transfer, incoming and outgoing...)
elkiwi
Be aware that if you use AA to answer calls that procedure is not possible. When AA answer a call public numbering plan is not used. In that case you have to configure virtual extensions diverted to secondary site.
