Can't load image file
aldorado
Post by aldorado »
Hello Dears,
I have a problem with an OS6450, when booting it, it gives me the following error;
Starting dynamic software load from '/flash/certified/'...
Unable to load image file 'loadBase.lnk'.
Certified: [Kernel]->
the switch still in waranty, but is there is any action which I can made to solve this problem?
could you please help?
Regards.
devnull
Re: Can't load image file
Post by devnull »
Do you have a small usb stick?
(try it on another switch "usb enable" "ls /uflash" should show you something)
Load the approprtiate images into
"usbstick/6450/certified"
(create dir /6450/certified)
create a aossignature File in root of usb stick
and try a disaster recovery, maybe you have to kill the certified directory on the switch before:
https://service.esd.alcatel-lucent.com/ ... umber=9973
aldorado
Post by aldorado »
Hello devnull,
unfortunately I don't have a USB stick :(
Is there is any commands that can help me to recover the corrupted file?
I tried the (II) command, and I got the following result:
Certified: [Kernel]->ll
drw 2048 Jan 4 2000 certified/
-rw 312 Nov 30 00:00 boot.params
drw 2048 Jan 4 2000 working/
drw 2048 Jan 31 2000 switch/
-rw 64000 Nov 30 00:00 swlog2.log
-rw 12 Jan 31 2000 boot.slot.cfg
-rw 64000 Dec 31 01:24 swlog1.log
drw 2048 Jan 31 2000 network/
60049408 bytes free
value = 0 = 0x0
is this is helpful?!
regards, and thanks for your help.
devnull
Post by devnull »
Well try to locate a 128MB-2GB USB Stick (bigger ones will probably not work) it's by far the easiest solution usefull for hasslefree sodtware updates as well..
I found a techdoc "OS6250 :Uboot/TFTP Based Image Transfer During Flash/File System Recovery" but i am not sure whether it fits 6450 as well (but should) https://service.esd.alcatel-lucent.com/ ... umber=8554
gamermic
Post by gamermic »
Did you manage to find any pmd file?
mixeysan
Post by mixeysan »
devnull wrote:Well try to locate a 128MB-2GB USB Stick (bigger ones will probably not work) it's by far the easiest solution usefull for hasslefree sodtware updates as well..
Where i can find this techdoc?
or pls send me mixeysan@gmail.com
Return to “OmniSwitch 6450”
