I've a problem between an OXE (4400) and an IP Phone. If all (both OXE and IPPhone) are on the same nework, no problem. But if my IPPhone is on an other network (VPN), using he IPPhone, I can hear other people but they cannot hear me.
I've checked tha i can ping the IP Phone from the 4400. I'm not filtering any protocol between my networks.
If someone as an idea ?
///in French :
Bonjour,
J'ai un soucis de VOIP entre un OXE (4400) et mes postes IP Phone. Si OXE et IPPHON sont sur le même réseua, j'ai un fonctionnement normal. Par contre, si mon IP Phone est déporté sur un réseau distant, lorsque j'établis une comm depuis l'IP Phone (4022), mon interlocuteur m'entend alors que je l'entends pas.
Depuis le 4400, je ping bien l'IP Phone. Je ne filtre aucun protocole sur mon tunnel VPN. Ce tunnel est établi depuis +sieurs années et utilisé pour d'autres applications sans soucis.
Si vous avez une idée...
IP Phone, One side hear me, I don't hear
Bebo
Hi Miko,
as you describe your problem, it is the network. But the question is how can you check it ?
It is possible that you can have a mirror port. So you can use Ethereal ( You can download from the internet) and check that the RTP pakets goes in both direction.
bebo
bebo
rotonpur_DUP
Re: IP Phone, One side hear me, I don't hear
Dear frank, Is it possible to add a download link for avisio Ver 3 here.
zanex
would hazard a guess that when you are on vpn you are being Nat'd (do you get an ip like 172.16.x.x 10.x.x.x or 192.168.x.x)
The problem is normally related to the various H.xxx streams and the dynamic port range getting lost as unless its an ALG or have H.323 support it doesnt know how to handle them
alcatec
Can you ping the INTIP card from the remote location? Perhaps the one-way audio is caused from the remote not being able to route back to the INTIP.
