signaling protocol on nprae
youfo007
Post by youfo007 »
hello,
on alcatel doc I found that the card may have two access nprae E1 CCS or two E1 CAS access.
for port 0 I configured the access E1 CCS
now how the second port configured on the E1 CAS access to a link with a map for PCM2 R signaling
thank you
krzysioD
Re: signaling protocol on nprae
Post by krzysioD »
for PCM2 R in a crystal hardware => you need a PCM2 card.
youfo007
Post by youfo007 »
thank you for the answer but I'll try with Card nprae.
krzysioD
Post by krzysioD »
Well, if you wish :)
in common hardware - would believe, only need to have a soldering iron.
In crystal - well - can't see it happen. R2 signaling just needs the PCM2 board.
Kindly, attach this doc here, will you? Quite interesting if it's a true one.
hi
so UFO does it work with NPRAE ? MEANS R2 under PRA!
SYSTEM DOC
NPRAE OFFERS 2 ACCESS E1-CCS
OR 1 acces for DASS2 or DPNSS
Only avalaible E1-CAS under T1 interfaces DPT1
FOR CRYSTAL AND R2 PCM2 is mandatory
youfo007
Post by youfo007 »
yes, this is what I found, so it w'd to buy an interface PCM2
krzysioD
Post by krzysioD »
Sometimes is good to ask :) before you buy.
BTW: cable is the same one.
i confirme cable TY2 SAME FOR E1 CCS(PRAX interface) and PCM2 (E1CAS,R2)
be sure that you provider is sending synchro (my ofs hasn't work if synchro wasn't sent or mal configured on r2 access).
youfo007
Post by youfo007 »
thank you for all the suggestion, I'll consider all this.
Return to “Shelf”
