Analog FCT - 30 seconds for call
alexandros_z
Dears
I have OXE R 9.1 and FCTs connected with APA board.
My problem is that each mobile call to FCTs needs 28 seconds to be established.
If i connect an analog set directly to FCT the time is only 11 seconds.
So i think that the PABX send the digits with a delay or something else is happened in the PABX configuration.
Does anybody have any idea how to solve this?
Thanks in advance for your support.
- tot3nkopf
Re: Analog FCT - 30 seconds for call
Check in external services trunk cos-->type of numbering-->should be mf q23. same setting should be on FCT (faster dialling than decadic).
alexandros_z
thanks i wil check it....
alexandros_z
Thank you very much!
It is working now properly ..!
alexandros_z
Hi again,
do you know how to send the end of dial digit (#) to the FCT? So i can reduce the total time by 5 more seconds.
When i dial "#" the PBX keeps it for itself and doesn't transmit it to FCT. I tried also to dial "##" but same result.
Really appreciated
Really appreciated
- tot3nkopf
Do you use ARS seizure or trunk seizure?
alexandros_z
I use ARS.
I tried to use numbering command table but i didn't found out how to send # digit at the END of dialed number.
- tot3nkopf
No just use predefined number of digits for some direction or configure timers 18 and 136.
alexandros_z
Thank you,
i didn't manage to send "#" to the FCT, but i configured the FCT "interdigit time out" timer to 1 sec.
I playd also with NPD but nothing. It should be configured by a way but i don't know how.
in specific telephone service what's the equivalent of end dialing?it should be #
check also system>>othe system parameters>>system parameters verifie that no end dialing is uncheked
for me ars or not the # wi=orks perfectly with different type of trunkgroup pcm , E1 ,NDDI
IF every thing is okay so chek timer mentinned by Toten ALSO dtmf on trkg
