IO2N - what can I do to stop CPU reset
clasex
Post by clasex »
I have a CPU5 step 3, with IO2N.
My IO2N is damaged and I do not need an IO2N board in my configuration anymore.
Without IO2N, CPU restarts at 30 seconds after initialization.
Of course I already deleted IO2N position from management Shelf > Board > 21
What can I do to stop cpu reset ?
I look forward for a response
stancu_adi
Re: IO2N - what can I do to stop CPU reset
Post by stancu_adi »
Reboot the OXE and stop the telephony by pressing CR key to stop the telephone application.
When you've got the prompt use the command : RUNTEL -DNOIO2
After that if you will not use anymore the IO2N boards delete the both IO2N boards and unplug them from the system.
BR,
Adrian
Return to “Shelf”
