Does anyone has ideas how I can call a phone number without programmable key or without introducing the number manually ?
Copy / paste from an notepad file for example doesn't work.
Thx for your feedback.
IP Desktop Softphone 4068
fbedia
Re: IP Desktop Softphone 4068
With ipDesktopSoftphone can not do what you want.facil-it wrote:Does anyone has ideas how I can call a phone number without programmable key or without introducing the number manually ?
Could combine with the program, Alcatel CCAgent. This allows to invoke a script at startup, or copy and paste into a textarea Call ...
You can develop an application using TSAPI or search in the forum for Tools and seek the development Frank did once to build an automated dialer.
ICS (OTUC) is another expensive option.
Actually you can do it, well on the latest version 10.0.1.3. All you do is copy the phone number you want to dial from somewhere, go to the top of the Softphone, right click and the number you copied will appear with a phone icon next to it. Click and it will dial that number. The only issue I have though is the number you copy must have the outdial number in it (0 for example), or you need to dial the outdial number first then right click and dial.fbedia wrote:With ipDesktopSoftphone can not do what you want.facil-it wrote:Does anyone has ideas how I can call a phone number without programmable key or without introducing the number manually ?
