when I added the new board then no pcm code indicated.
thkim81
Post by thkim81 »
hi~
I added the new board. It is not in mao.
I did order only board.
board status is normal. but when config command enter, board coupler ID is no pcms code
is this normal or not ?
maybe this status concern with hardware.mao file.
pls answer the question.
thnaks
Re: when I added the new board then no pcm code indicated.
This is normal. No other operation required.
thkim81
Post by thkim81 »
thanks tot3nkopf
so I configue two cabinet connected with INTOF board.
and carrier is only cabinet 2 not cabinet 3.
when I testing the calling , first, cabinet 2 INTIP resource full using, then cabinet 3 INTIP resource use.
this case is concern with nprae2 board ?
maybe I think NPARE2 board in cabinet 2, so first cabinet 2 INTIP board resource full use then cabinet 3 calling to go.
Is that right ?
If you have high traffic additional compressors must be taken into consideration for traffic between shelves.
Return to “Shelf”
