i have OXE R9.1 and use CS-2 board, i face this case:
the CS-2 it was working ok ,for maintenance reasons, When i pull the CS-2 board from the chassis (from its slot 8 in Rack 3) and then reinstall it in same slot it doesn't start up !!!!!!!!!!!!!
But after several attempts, or after he leaves for a period of 3-6 hours is working again
When i use CS board with same rack 3 , it work directly, and when i install CS-s in small rack it works directly also!!
Try 3 chassis rack3 and got same case
I face this same case with 2 OXE systems work with CS-2 !!!
can any one help me
