Hi everyone. Sorry for my poor english
R10.0-j1.410-34-c-ii-c82
I have a problem with connecting GD2 board to CS trough WAN
CS(192.168.1.3)--->192.168.1.1)Router1(172.31.232.12)------(172.31.232.13)Router2(192.168.100.1)<----(192.168.100.3)Media Gateway
GD2 writing that
/usr/bin/binmg_download: download of binmg failed: file not found on server or bad transfer or file corrupted
lanpbxbuild:
IP CPU 1: 192.168.1.3
CS_MODE = NOE
IP download RD: 192.168.1.3
CS_MODE = NOE
[root@xxxx10 mtcl]# tcpdump -s 1500 -vvv port 69
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 1500 bytes
14:15:36.777239 IP (tos 0x0, ttl 62, id 2, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
14:15:36.793736 IP (tos 0x0, ttl 62, id 3, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
14:15:41.782325 IP (tos 0x0, ttl 62, id 4, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
14:15:41.782379 IP (tos 0x0, ttl 62, id 5, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
14:15:43.133634 IP (tos 0x0, ttl 62, id 39237, offset 0, flags [none], proto: UDP (17), length: 168) 192.168.99.1.1025 > sandang.tftp: [udp sum ok] 140 RRQ "/DHS3bin/downbin/mg3/binmg3" octet ethernetaddress xxxxxxxx crystalnumber 3 couplernumber 0 subnetmask ffffff00 blksize 1024 timeout 2
14:15:46.789599 IP (tos 0x0, ttl 62, id 6, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
14:15:46.789652 IP (tos 0x0, ttl 62, id 7, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
14:15:47.122625 IP (tos 0x0, ttl 62, id 39238, offset 0, flags [none], proto: UDP (17), length: 168) 192.168.99.1.1025 > sandang.tftp: [udp sum ok] 140 RRQ "/DHS3bin/downbin/mg3/binmg3" octet ethernetaddress xxxxxx crystalnumber 3 couplernumber 0 subnetmask ffffff00 blksize 1024 timeout 2
14:15:51.146701 IP (tos 0x0, ttl 62, id 39239, offset 0, flags [none], proto: UDP (17), length: 168) 192.168.99.1.1025 > sandang.tftp: [udp sum ok] 140 RRQ "/DHS3bin/downbin/mg3/binmg3" octet ethernetaddress xxxx crystalnumber 3 couplernumber 0 subnetmask ffffff00 blksize 1024 timeout 2
14:15:51.781535 IP (tos 0x0, ttl 62, id 8, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
14:15:51.783959 IP (tos 0x0, ttl 62, id 9, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
14:15:55.135804 IP (tos 0x0, ttl 62, id 39240, offset 0, flags [none], proto: UDP (17), length: 168) 192.168.99.1.1025 > sandang.tftp: [udp sum ok] 140 RRQ "/DHS3bin/downbin/mg3/binmg3" octet ethernetaddress xxxxx crystalnumber 3 couplernumber 0 subnetmask ffffff00 blksize 1024 timeout 2
14:15:59.118822 IP (tos 0x0, ttl 62, id 39241, offset 0, flags [none], proto: UDP (17), length: 168) 192.168.99.1.1025 > sandang.tftp: [udp sum ok] 140 RRQ "/DHS3bin/downbin/mg3/binmg3" octet ethernetaddress xxxxx crystalnumber 3 couplernumber 0 subnetmask ffffff00 blksize 1024 timeout 2
14:16:10.676000 IP (tos 0x0, ttl 62, id 39242, offset 0, flags [none], proto: UDP (17), length: 168) 192.168.99.1.1025 > sandang.tftp: [udp sum ok] 140 RRQ "/DHS3bin/downbin/mg3/binmg3" octet ethernetaddress xxxxx crystalnumber 3 couplernumber 0 subnetmask ffffff00 blksize 1024 timeout 2
14:16:14.682030 IP (tos 0x0, ttl 62, id 39243, offset 0, flags [none], proto: UDP (17), length: 168) 192.168.99.1.1025 > sandang.tftp: [udp sum ok] 140 RRQ "/DHS3bin/downbin/mg3/binmg3" octet ethernetaddress xxxxxx crystalnumber 3 couplernumber 0 subnetmask ffffff00 blksize 1024 timeout 2
14:16:18.677982 IP (tos 0x0, ttl 62, id 39244, offset 0, flags [none], proto: UDP (17), length: 168) 192.168.99.1.1025 > sandang.tftp: [udp sum ok] 140 RRQ "/DHS3bin/downbin/mg3/binmg3" octet ethernetaddress xxxx crystalnumber 3 couplernumber 0 subnetmask ffffff00 blksize 1024 timeout 2
14:16:19.462184 IP (tos 0x0, ttl 62, id 0, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
14:16:19.462238 IP (tos 0x0, ttl 62, id 1, offset 0, flags [none], proto: UDP (17), length: 78) 192.168.99.1.1024 > sandang.tftp: [udp sum ok] 50 RRQ "lanpbx.cfg" octet timeout 5 blksize 1428 tsize 0
1
xxx: mac addres my GD3
but if i connect in 1 switch the GD 3 can connect with the cs, but if connect trough WAN can'n connect.
I have registered GDs MAC address in Shelf/Board/Ethernet parameters.
Registered tftp address in lanpbxbuild but nothing.
Maybe some idea?I don't know what to do else.
problem conect GD 3 to CS
yoganza_88
Re: problem conect GD 3 to CS
i try
lanpbxbuid -auto
but i was can't connect..
any one help me?
lanpbxbuid -auto
any one help me?
If when you connect CS and GD in one switch everything Ok but via WAN not - as I understand you can have only two problems:
- in CS (netadmin) and/or GD-3 (mgconfig) parameters declared wrong parameters (IP address, mask or gateway address);
- in network disabled some protocols (f.e. tftp), IP routes or wrong management in NAT.
yoganza_88
I try use call server by VM Ware same release with CS-2. and then the GD-3 can connect to my Call Server ( CS-2) and IP Phone connect too.
Can the PABX ( CS and GD) connect through internet by VPN Tunnel?
Maybe a idea to increase the tftp block size?
under ip / ip parameters / tftp blocksize increase it from 14xx to 1024 just to test?
