Directory names don't displayed on the extension of node 2
jpissot
Post by jpissot »
First of all, Happy new year everybody!!!
I have two nodes (1 and 2) on a network 0.
The 2 nodes are interconnected by a full IP link.
Audio between the 2 nodes is OK.
The problem is when an extension of the node 1 call an extension of the node 2, the directory name of the extension of the node 1 don't display on the extension of the node 2. It's the same when the communication is established. Only the directory number is displayed.
When the extension of the node 2 call an extension of the node 1, the directory name appears on the extension of the node 1.
Before, the link between the 2 nodes was an hyrbrid link with VPN overflow with T2, the problem was similary.
If you have an idea....
Return to “Inter-Node Links”
