Omnivista CMISE error
Xero
Post by Xero »
Hi all,
I have recently migrated a customer from OXE R 7.1 to R9.1 and hav upgraded omnivista from 4.2 to 5.1, i have synchronized omnivista without any problems, but when i try to use configuration i get a message CMISE reject, i have read some old posts here about the same subject matter and by using their tips n suggessions i have done dhs3_init -R CMISD but issue didnt resolve, i have not changed any passwords for ftp so this is not the problem with passwords, i have also kept cmise password disabled in omnivista, i have tried reinstalling omnivista on other machines too but issue still persists, can anyone help me out??
Re: Omnivista CMISE error
May be you have wrong configuration for connection (in 4760). In old 4760 release - you need to declare only adfexc (ftp) password. In new as I remember - you need to declare mtcl (or/and?? swinst) password.
Xero
Post by Xero »
do you mean mtcl in CMISE password or somewhere else?
mia
Post by mia »
If there is duplication, try a double bascul...it worked for me!
luis.molinas
Post by luis.molinas »
Hi Xero, can you solved this issue? I have the same problem.
Best Regards.
sami_1244
Post by sami_1244 »
I have CMISE issue when i was trying to use mgr command.
I have redundency, can i use bascul?
If you use mgr command on stand-by CPU - you have no CMISE error?
Sometimes - bascul can help.
Sometimes - after bascul you can have problem (Especially if the databases are not identical) .
luis.molinas
CMISE error is a software protection issue, we need to wait some timer(24 hours) until the next verification of the license between OXE and OV.
Return to “OmniVista 4760”
