How to change the severity of snmp incidents
wizkash
Post by wizkash »
Hello everyone,
I have a requirement to change the severity of SNMP incidents. Is it possible and if yes could you please tell me how we can achieve this.
For example: an incident with severity minor, can we change it to critical / and vice versa.
Thank you.
alex
Re: How to change the severity of snmp incidents
Post by alex »
If you are talking about traps sent by OXE then check System Documentation/Maintenance/SNMP management/Configuration procedure/Additional Management/Configuring Data Linked to the SNMP Service.
Return to “SNMP Configuration”
