Switch over of CS
BANNAIRE
Switch over of CS
Post by BANNAIRE »
Hello all
My problem :
OXE R9.1 two gateways, redundancy on, both call servers on the same subnetwork
When the CPUA is main, if I shutdown the CPUA, the switch over is OK, CPUB goes main and CPUA goes standby after reboot
When the CPUB is main, if I shutdown the CPUB, the CPUA reboots also (something like a broadcast message)
This is the netadmin configuration of both CPU. Did I do anything wrong ?
CPUA
Your system has the private network number 0 and the site number 4.
Private IP addressing space: no
Restricted internet accesses: no
Accept ICMP redirect: no
Low dynamic ports range configuration : 10000 - 10499
There is no VLan configuration. No frame will be 802.1q-tagged.
The ethernet redundancy is not supported on this CPU type
node name : noeud4
internal name resolver activated : no
Ethernet interface setup
Netmask : 255.255.255.0
| Machine type | Local interface | Name | Address |
| local | Ethernet | oxer9a | 192.168.0.70 |
| local main | Ethernet | main_oxe | 192.168.0.14 |
| local | IP/X25 tunnel | x000004_tun | 172.30.253.4 |
<return> to continue.
CPU redundancy setup
| local | Ethernet | oxer9b | 192.168.0.71 |
CPUB
node name : noeud4
Role adressing on both CPU
| twin main | Ethernet | main_oxe | 192.168.0.14 |
smileyman
Re: Switch over of CS
Post by smileyman »
He Bannaire,
what ist your patch-level? - In Release 9.1 with a low patch-level is a bug.
Best regards
smileyman
BANNAIRE
Post by BANNAIRE »
He
The relaese is I1 605.21. But this release works perfectly on other sites
smileyman
Post by smileyman »
Hi Bannaire,
you are right. - I mean this: crms00256662 (dup of crms00255559): Stand-By CPU freezed after bascul (following a translation from Release 7.1.
But this is not your problem, i think.
Is 'twin' ok?
Best regards
smileyman
BANNAIRE
Post by BANNAIRE »
Yes, twin is OK on both CPU
RobertBreu
Post by RobertBreu »
what happens if you do a bascul?
BANNAIRE
Post by BANNAIRE »
The standby CPU goes main and reboots after a few seconds. So both CPU reboots
There is a message like this on the CPU which goes main
Broadcast message from root Sun Sep 11 19:21:50 2011...
The system is going down for reboot NOW !!
smileyman
Post by smileyman »
Hi Bannaire,
please provide a incvisu from both CPUs. - I hope to see more.
Best regards
smileyman
BANNAIRE
Post by BANNAIRE »
Here incvisu of both CPU. At one moment, just after the Bascul, there are two call servers main. This is the reason, what do you think ?
RobertBreu
do you have configured a reference media-gateway and/or a preferred main com server?
Return to “Media Gateway”
