Incident PCM R2 board
Hi people
What is your opinion about this incident?
04/09/11 18:22:05 000001M|005/06/-/---|=3:0011=ERROR : SU functioning 6
04/09/11 18:22:30 000001M|005/06/-/---|=3:0011=ERROR : SU functioning 6
It is a PCM R2 board. There's no problem with the calls through it. Everything works fine.
Thanks.
Thanks.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
zap_ldu
Re: Incident PCM R2 board
hello. enio.eltz you can solve your problem? i have the same error.
No, but I don't have issues, it is just this incident that I would like to know.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
pedro_alcatel_br
Hi fellas,
I've the same incident... and also no problems with calls...
Does anyone have any news about this?
Isalcatel
I have the same incident. If anyone have information about this I'll be glad to know.
Ahhh marvels of Brasilian R2 which is a modification of the standard R2. Why? No clue. Had a long talk some time ago with a guy who had years here and I was surprised by it.
It shouldn't happen and that is why pbx complaints. But as far as I have traced it doesn't affect the functionality at all
What does incinfo GEA 11 tells you?
Never seen before...
Hi Eliott
It tells:
Best regards.
It tells:
But I don't have problems with the calls through the TG where the incident is showing.Decompressing /tmpd/incid_GEA.txt
INCIDENT NUMBER: 11
OBJECT CLASS: Dhs3Board
EVENT TYPE: ProcessingErrorAlarm (10)
PROBABLE CAUSE: Unknown (0)
SEVERITY: Minor
"ERROR : SU functioning P1"
"P1 : Number of SU error"
"Fonctioning error on signalling unit"
"The SU cannot interpret an order sent by the CPU."
"no reaction of the system."
"Check the configuration for the equipment indicated by its position. If the"
"configuration is correct or if the equipment is of the "TERM_ALARM" type, note""
"the incident with all its information on an observation sheet (problem report),"
"specifying if possible the error context.";
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
So something in the signalling is not understood. Mmm. As you say you have no issue I agree with cav and you => Ignore it.
