4038 / 4068
4038 / 4068
I just installed those IP Touch phone today for the first time.
They rock !
I read that we can program XML to change everything on the display ?
Anyone has a doc on that ?
Thx
rdclan
Post by rdclan »
that XML Thing is very intresting.
I would like to bring some info , like Daily Canteen Menu, on the Display of my new Phone.
Anyone Has Information how i can do that ?
la_toupie
Post by la_toupie »
:shock: :shock: :shock:
Good idea, I have not yet it but if it works, i use immediatly of this soft.
bbocjcp
Post by bbocjcp »
The link to the web page containing Alcatel's XML guides, APIs and docs is freely available here ..
http://www.applicationspartner.alcatel. ... Interfaces
nyt88888
ip phone codec
Post by nyt88888 »
hi, may i know how where can i find what is the codec being used by the ip phone. i tried to telnet into the ip phone but could not find anything useful
bbocjcp
Post by bbocjcp »
I believe the codec being used depends on the domain that the phones are configured into.
The default would be a G.711, but if you configure the phone into a remote domain, across a lower bandwidth link, then it would be G.729a
-Conrad
nyt88888
Post by nyt88888 »
this is the default in the MAO. thus i would presume that it is using G723. where can i find more information about the domain of the IP phone configuration.
┌─Consult/Modify: Compression Parameters─── │ │
│ Instance (reserved) : 1 │
│ System_Option + Compression type │
│ Compression type + G 723 │
alex
Post by alex »
Hi folks
Anyone tried to install some XML Web services on 4038/4968?
I contacted local Alcatel representative about any demo... still no reply.
One customer wonders whether iit is possible to have weather report on 4068?
What is really needed?
Looks like it is kind of real but how?
tsjade
Post by tsjade »
anyone has low volume & echo issues for 4068 ip phones?
aalmanzar_DUP
Post by aalmanzar_DUP »
I think you need a license in order for you to used xml on the IP Touch Phones,
Any one with different answer let us know
thanks
Return to “IpTouch Phones XML Applications”
