After One Ring The Call is disconnecting in ABCF-IP Logical
kumaran
Post by kumaran »
I had two OXE Systems with R9.0 and R9.1 . I had Created ABC-F IP Logical Link and also VPN Overflow . The Link is up and also VPN is up but if call the remote node Extension number after one ring call is getting disconnected Same behaviour is happening at both the sides.
kumaran
Re: After One Ring The Call is disconnecting in ABCF-IP Logi
Post by kumaran »
Hi ,
Any body is there to solve this issue...
If you have hybrid link - signalling on IP and VPN overflow - show at least t3 trace (from both sides).
kumaran
Post by kumaran »
In t3 traces in both side it saying normal unspcefied normal call clearing . But the call is hitting on both sides.
kumaran
Post by kumaran »
Hi ,
This is node 1 traces..
t3
--> Cleaning mtracer...
| 0 | ** | ** | * | ** | * | *** | 165 |
| 1 | ** | ** | * | ** | * | *** | 166 |
| 2 | ** | ** | * | ** | * | *** | 167 |
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
Traces Analyser activated
mtracer started ...
(057384:000001) MTRACER host (10.2.42.7, main), version: R9.0-h1.301-50-a-et-c7s2
(057384:000001) MTRACER num: 009, time: 2011/08/31 15:29:47, loss: 0%
| (057482:000002) 1056: Send_IO1 (link-nbr=15, sapi=0, tei=0) :
| long: 104 desti: 0 source: 15 cryst: 0 cpl: 15 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 00 33
| [9f] Non-locking shift. codeset : 7
| [a1] EI_IP_TYPE_NODE
| IE:[05] EI_IP_INFOS (l=9) -> G723 Ece 1 Vad 1 Profil 2, IPv4 :192.168.13.22.
| IE:[06] EI_IP_PAYLOADS (l=1) -> G729 Ece 1 Vad 1
| IE:[07] EI_IP_QOS (l=3) b8 a0 00
| IE:[0a] EI_RTP_INFO (l=30)
| -> stop_packet=0 stop_rtp=0 h323=0 wc=0 rf=0 udp=1 rqm=0
| -> Transm_Bande=1 detection_Q23=1 dtmf_payload=96
| -> Port RTP = 32514, IPv4 : 10. 2. 22. 50.
| -> Port RTCP SR = 32515, IPv4 : 10. 2. 22. 50.
| -> Port RTCP RR = 32515, IPv4 : 10. 2. 22. 50.
| -> Port Fax = 0, IPv4 : 0. 0. 0. 0.
| IE:[18] CHANNEL (l=3) a8 83 81 -> T2 : No B channel
| IE:[6c] CALLING_NUMBER (l=5) -> 80 Num : 1299
| IE:[70] CALLED_NUMBER (l=5) -> 80 Num : 7100
| IE:[7d] HLC (l=2) 91 81
| [a1] Sending complete
| (057482:000004) Concatenated-Physical-Event :
| long: 21 desti: 0 source: 0 cryst: 0 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 80 33
| IE:[18] CHANNEL (l=1) a8 -> T2 : No B channel
| (057497:000005) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 0 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : 80 33
| [97] Locking shift. codeset : 7
| IE:[0a] EI_RTP_INFO (l=2)
| -> stop_packet=0 stop_rtp=0 h323=0 wc=0 rf=0 udp=0 rqm=0
| (057497:000006) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 0 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 80 33
| IE:[08] CAUSE (l=2) 81 9f -> [9f] NORMAL, UNSPECIFIED
| (057497:000007) 1056: Send_IO1 (link-nbr=15, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 0 cpl: 15 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 00 33
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
t3
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
mtracer started ...
(020717:000001) MTRACER host (10.2.42.7, main), version: R9.0-h1.301-50-a-et-c7s2
(020717:000001) MTRACER num: 004, time: 2011/08/31 17:44:03, loss: 0%
| (020761:000002) 1084: Send_IO1 (link-nbr=15, sapi=0, tei=0) :
| tei: 0 <<<< message sent : SETUP [05] Call ref : 00 0b
| (020761:000004) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 80 0b
| (020775:000005) Concatenated-Physical-Event :
| tei: 0 >>>> message received : ALERT (01) Call ref : 80 0b
| (020775:000006) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 80 0b
| (020775:000007) 1084: Send_IO1 (link-nbr=15, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 00 0b
kumaran
Post by kumaran »
This is Node 13 t3 traces..
t3
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
mtracer started ...
(223598:000001) MTRACER host (192.168.13.21, nrbibah), version: R9.1-i1.605-25-b-ke-c82
(223598:000001) MTRACER num: 004, time: 2011/08/31 17:43:03, loss: 0%
| (223631:000002) Concatenated-Physical-Event :
| long: 41 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 10
| SENDING COMPLETE
| IE:[18] CHANNEL (l=1) a3 -> T2 : Any B channel
| (223631:000003) 1183: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 34 desti: 0 source: 15 cryst: 2 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 10
| IE:[06] EI_IP_PAYLOADS (l=2) : (COMP/ECE/VAD) -> G723/1/0 G729/1/0
| (223631:000004) 1183: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 51 desti: 0 source: 15 cryst: 2 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 10
| -> Port RTP = 32616, IPv4 : 192. 168. 13. 22.
| -> Port RTCP SR = 32617, IPv4 : 192. 168. 13. 22.
| -> Port RTCP RR = 32617, IPv4 : 192. 168. 13. 22.
| (223631:000005) 1182: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 10
| (223631:000006) 1183: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 80 10
| (223632:000007) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 00 10
| (223633:000008) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 00 10
| (223633:000009) 1183: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 80 10
Return to “Inter-Node Links”
