INTOF Board having problem;Syn Indication is coming on it.
abhishek1987
Post by abhishek1987 »
Hi ,
I am a filed Engineer . One of My Customer -Crisil-SEZ -Powai has Alacatel -OXE-Crystal H/W R8.0.1-g1.503-11-in-c7s2.When I see the incidents in incvisu I am getting the Incidents as follows:
(1)cpu_a> incvisu -t 10
19/06/11 15:33:30
01/08/11 13:32:39 000001M|000/04/-/---|=0:3660=status of 8KFS (0 is OK, 1 is KO)
: 1 , value : 4 2
: 0 , value : 4 4
01/08/11 13:32:40 000001M|000/04/-/---|=0:3660=status of 8KFS (0 is OK, 1 is KO)
: 1 , value : 4 6
: 0 , value : 4 4
01/08/11 13:32:44 000001M|000/04/-/---|=0:3660=status of 8KFS (0 is OK, 1 is KO)
: 1 , value : 4 3......
Plz Suggest........Also Syn indication is coming on INTOF Card....
Re: INTOF Board having problem;Syn Indication is coming on i
Some additional info?
Problem was absent but now exist - or you install new boards.
Optical or copper connection (for copper not used TY1 cable, only INT_INT or TY2)?
Exist or not another incidents (like problem with PRA2/NPRAE boards)?
If you change INTOFA/INTOFB - you have the same problem?
abhishek1987
I did not get U..Can U plz Elaborate a Little...Also INTOF Card Syn Indication is coming on the Card......Also When I Logged in to the MAin Cpu (192.168.1.12-Main Physical ) & gave bascul Command , Many Extensions were down , Also Checked the twin Status Continously & when I got all ready, gave BAscul Command again , So the MAin CpU again got its Role back from Standby to MAin.......But the Problem didnt got resolved ....So I Hard rebooted the CArds ...>Finally The Problem got resolved but When We see the Listerm in Both Cpu , There is some Issue; In MAin CPU the Extensions are through i.e. dotted....... bt the Standby.....the State is ...........B.... But the Extensions are OK by now.....
My questions was:
- problem exist long time or start one (two, three..) days ago.
- connection via COST-MO (MU) board - optical link or copper (INT-INT cable f.e.).
- if you change INTOFA and INTOFB - INTOFA insert instead of INTOFB, INTOFB insert instead of INTOFA - something changed or not?
abhishek1987
Have not InterChanged the INTOF Card as U Suggested ; The Site is Very Business Mission Critical type .Plz Suggest. No its not Copper ; The BAck end is Normal Emphenol Cable.
Deepakz
Post by Deepakz »
Vad,
First Thank You,
In this site we cloned system because of synchronization problem & Chorus IPC alarm. But after that, this error come out.
01/08/11 13:32:44 000001M|000/04/-/---|=0:3660=status of 8KFS (0 is OK, 1 is KO) : 1 , value : 4 3.....
and card is showing syn alarm.
INTOF card is connected through TY2 cable.
and it is old one only.
Please suggest.
Check connections, check - in INTOF board not managed synchropriority (255).
Check with "infocs" - PBX synchronized from PTT (and no problem with synchro).
Deepakz
Post by Deepakz »
Thank You. I will do that.
wadsultan
Post by wadsultan »
HI SDEEPAK
Please tell me how you solve the problem,because I have same problem in one system? waiting for your reply.
Best regards
Wadsultan
wadsultan wrote:HI SDEEPAK
Best regards
Wadsultan
Try as Vad suggested to reverse INTOF boards. The reason for this is sometimes INTOFB does not download new binaries.
Return to “Shelf”
