GD3 reboot
alcaman
GD3 reboot
Post by alcaman »
i have a problem with a GD3 Board and i need our support.
my oxe Rel 9.1-i1605-25-b.
2x large shelf with hsl link connection and a separate small shelf with pcs ip connection not active.
incvisu :
18/07/11 17:44:39 000001M|002/00/0/254|=2:0379=Inter ACT link HS: 23,(19,1),192.168.115.101,00:80:9f:8e:a8:44
18/07/11 17:44:39 000001M|002/--/-/---|=2:2043=Loss of the 2 CRYSTAL
18/07/11 17:44:39 000001M|002/00/-/---|=2:2042=Loss of a GD/GD3 type cpl
18/07/11 17:44:39 000001M|002/02/-/---|=2:2042=Loss of a UA type cpl
18/07/11 17:44:39 000001M|002/06/-/---|=2:2042=Loss of a PRA type cpl
18/07/11 17:44:39 000001M|002/07/-/---|=2:2042=Loss of a BRA type cpl
18/07/11 17:44:39 000001M|---/--/-/---|=2:2140=Alarm : TRUNK resources quantity critical
18/07/11 17:44:39 000001M|003/--/-/---|=2:2043=Loss of the 3 CRYSTAL
18/07/11 17:44:39 000001M|002/27/-/---|=3:2490=Loss of a virtual coupler GPA (2,27) of the associated coupler GD/GD3 (2,0)
18/07/11 17:44:39 000001M|003/00/-/---|=3:2490=Loss of a virtual coupler GPA (3,0) of the associated coupler MEX (3,0)
18/07/11 17:44:39 000001M|003/01/-/---|=2:2042=Loss of a UA type cpl
18/07/11 17:44:39 000001M|003/06/-/---|=2:2042=Loss of a BRA type cpl
18/07/11 17:44:39 000001M|003/08/-/---|=2:2042=Loss of a Z type cpl
where is the failure. have you an idea?
please, can you help me?
enio.eltz
Re: GD3 reboot
Post by enio.eltz »
hi
When GD3 goes ok again, probably incvisu shows an alarm like this "GD reason of the reboot". Can you show them?
It can be lost of connection with CS.
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
alcaman
Re: GD3 reboot
Post by alcaman »
hi,
yes i can show this.
18/07/11 17:47:11 000001M|002/00/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 2
regards,
enio.eltz
Re: GD3 reboot
Post by enio.eltz »
Hi alcaman
incinfo has shown us this:
INCIDENT NUMBER: 5857
OBJECT CLASS: Dhs3Board
EVENT TYPE: ProcessingErrorAlarm (10)
PROBABLE CAUSE: Unknown (0)
SEVERITY: Indeterminate
"GD/GA/INTIP/RGD: reason of reboot P1"
"P1 Error state"
"P1:"
"GD/GA code:"
"- 0: Reset by "reboot" or "shutdown -r" command"
"- 1: Reset on exception of the real time task"
"- 2: Hardware reset on loss of DL IP"
"- 3: Soft reset on loss of DL IP"
"- 4: Soft reset on loss of DL backup"
"- 5: Bad initialization with Call Server"
"- 6: Time out in phase of initialization"
"- 7: Reset by "rstcpl" command"
"- 8: Update of binaries"
"- 9: Update of parameters with mgconfig"
"- 10: Update of parameters with UAconfig"
"- 11: NMI Watchdog"
"- 12: Update of bios"
"- 13: Power off on GD/GA or Reset by "rstcpl" command on GA"
"- 14: Not enough memory for the real time task"
"- 15: Reset on exception in the Linux core"
"- 16: Not enough buffer descriptor"
"- 17: Reset on not obtaining IP parameters from the DHCP server"
"- 18: Change of IP parameters by the DHCP server"
"- 19: No renewal of IP parameters on expiration of the lease time"
"- 20: Backup configured but not validated (DHCP mode is configured)"
"- 21: Reset on startemg file not received and no backup mode"
"- 22: Reset on lanpbx.cfg file not received when CS address"
" : is dynamic and no backup mode"
"- 23: Time out in phase of waiting of backup or IP establishment"
"- 24: Software anomaly"
"- 25: Reset with the re-establishment of the power supply"
" : if DL IP is KO"
"- 26: Reset with the re-establishment of the power supply"
" : during the stop of the CPU applications"
"- 27: Reset with the re-establishment of the power supply"
" : when the CPU applications are stopped"
"- 28: Reset on Ethernet link test failed at system startup"
"- 29: Reset on back panel - communication lost between GD and GA"
"- 30: Reset on connect not received"
"- 31: Reset for PSK update"
"- 255: Unknown reason:"
" : - impossible to store reason in flash"
" : - defective ramdisk"
" : - impossible to treat NMI watchdog"
" : - stop of the system on empty battery"
" : - hot unplug"
In your case: "- 2: Hardware reset on loss of DL IP". Check LAN connections. Maybe somebody tells us the meaning of DL in this error.
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
alcaman
Re: GD3 reboot
Post by alcaman »
hi enio,
thx for the quickly information.
Lan Connection, mh. CS-Board, GD-Board connect over SLAN-4.
I configure the gd board with full 100 mb, is this correct?
enio.eltz
Re: GD3 reboot
Post by enio.eltz »
I keep my GDs always as auto negociation, option 1, see below.
Current duplex mode is: auto-negociation
Enter new duplex/speed mode :
0: auto-negociation (half duplex only)
1: auto-negociation
2: 100 Mps/full Duplex
3: 100 Mbps/half-duplex
4: 10 Mbps/full-duplex
5: 10 Mbps/half-duplex
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
alcaman
Re: GD3 reboot
Post by alcaman »
hi enio,
thx, first i changed the speed mode of the gd board.
i checked the lan later.
regards.
enio.eltz
Re: GD3 reboot
Post by enio.eltz »
OK, let's see what it happens...
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
FN_DK
Re: GD3 reboot
Post by FN_DK »
Hi Guys,
We have had excatly the same errors on a customer site, did it help to change the speed mode?
Strange, the system have been running 3 months with no problem, then suddenly, massive resets of the GD3...
Best Regards
fernasneri
Re: GD3 reboot
Post by fernasneri »
Anyone know what the message means reason of reboot 21: Reset on startemg file not received and no backup mode???
Return to “Media Gateway”
