Hi people!!!
Ineed hel urgently, i'm goign crazy trying to configure a VPN between two OA 5510 USG i tried lot of things, watched manuals and there's no way to activate the VPN, can anybody help me with it?
Thanks a lot
VPN with 2 Omniaccess 5510 USG
- tot3nkopf
Re: VPN with 2 Omniaccess 5510 USG
Do you have license for VPN?
Eigus
Of course, the license are installed and validated in both routers, i can configure the IPSEC, but reviewing the log in both routers, i see that it cannot run the IPSEC engine...
Could be a firmware issue?
- tot3nkopf
I doubt. Maybe configuration problem.
See this:
See this:
shawona
Does a vpn connection cost any money? i have a palm centro, but i dont have the internet on my plan. i saw something about using vpn, but i dont want to get charged for using the internet. basically, im asking if connecting to a vpn is free, or would i have to pay money to sprint.
Eigus
Thanks for the docs tot3nkpof...i've updated both routers to the last release and i'll check the configuration of your docs and see what happen...i'll tell you something ok?
