Voice guides in common harware
enio.eltz
Post by enio.eltz »
Is it possible to have 5 languages in common hardaware? The profile is OXE R9.1/CS-2/GD-3. Can GA/GA3 be the solution? I know this can be a stupid question but...
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
krzysioD
Re: Voice guides in common harware
Post by krzysioD »
yeap, it's stiupid or lazy, as it is 4 minutes check:
-open actis, quote 5 languages for pbx with 20 UA users, how it does look like?
-go mgr, shelf, board, Voice Guide Index MG, you have 4 slots, now does there is a possiblity to select 2&3 and 4&5 or not?
enio.eltz
Post by enio.eltz »
Hi Krzysio D
Thanks for your fast reply. This was the information I needed:
With this GD3 reads hotadpcm.EN0.ES0, for example.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
krzysioD
Post by krzysioD »
hotadpcm is a hotel voice guide... you didn't mention that you have a hotel...
anywhay: Actis: 3 minutes, telnet to a pbx and use mgr: 1 minute.
enio.eltz
Post by enio.eltz »
So, excuse me about the hotel. But yes, it's a system I will install in a hotel. Lock 5 and 10 are set to 1. After I created VG index MG as 2 & 3 and 4 & 5, GD3 has read the files from CS-2. Now I am testing them.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
enio.eltz
Post by enio.eltz »
When I try to change the set language (administrative or room ), the languages from 2 to 5 aren't broadcasted, it just has busy tone when I call a busy set for example. When I don't use index 2&3 and 4&5 it works.Something I am missing...
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Return to “Media Gateway”
