I have a R9.1 MG system with GD+MADA3 and GA+MADA3 in the rack, and also a remote rack with GD/MADA1(8 compressors).
I use only SIP for voip, have ~10 SIP users, around 300 users behind a client PBX on 2xE1 tg, and finally a SIP trunk to an operator. H.323 is not used.
What should I put into GD/GA config on compressors, in order to have the widest SIP trunk to my voip operator so TDM users don't get the busy beep?
In the docs I read only the following:
GD/GA/INT-IP boards:
Object name: Shelf > Board, attributes: No. of Compressors for Gateway and No. of Compressors for IP Devices
These two parameters are used to assign certain board compressors to the Gateway H.323 function and others to calls to IP-Phones and Media Gateways.
Example: to take into account the bandwidth of the link between nodes 1 and 2, the number of calls is restricted to 5. On the boards which support the logical link, the maximum number of compressors for the gateway function is configured at 5.
Please advise! Thanks.
