OXE Busy Camp on
hawai50
OXE Busy Camp on
Post by hawai50 »
Hi;
Is posible to put this value to FALSE when we create new users ?????
User/Dynamic State User/Busy Camp on: By default: TRUE
Thanks in advance
jigareda
Re: OXE Busy Camp on
Post by jigareda »
I want to do the same issue.
Did you get any solution?
Thanks,
Maybe create a template of an existing user?
jigareda
Post by jigareda »
I tried to create a user from "User by profile" from another existing user with Busy Camp on = false. But in this case it did not translate this field. Then it was equal to default value = true.
Any idea to change this default value to false?, because since now I need to create all the users with Busy Camp on = false.
Thanks in advance,
Can't. What you can do maybe is import via Omnivista or 4760i. You export to excel and import with data modified as you wish to
May be stupid question but - why you need this? In what case (external or internal calls)?
For external calls more easy to manage Public Network (Access) COS - Incoming DID hold on busy set=0
In additional, as I remember - for some set type (analogue) - not possible to change item Busy Camp-on.
jigareda
Post by jigareda »
Yes, I wanted to apply for external calls in all users (created and new).
I tried to change in Public Network COS - Incoming DID hold on busy set=0. And it worked fine.
Thanks a lot,
Is it me or are we confusing threads?
murraya
Post by murraya »
well Hawai50 opened it a few years ago an no response. jigarenda now wants the same info so why not post here? I think he was looking a littel deeper than needed with the dynamic state as it can be handled at the incoming level.
hope this clears it up Cav :)
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “Users”
